Luczorama is proud to launch a 4-week scavenger hunt giveaway packed with creativity, laughs, and nautical nonsense. Explore historic ships, solve easy clues, and have some fun with fellow builders. Complete weekly missions to earn raffle entries — the more you join in, the better your chance to win a Fram model ship by OcCre! **VIEW RULES HERE** |
They are in chineese language only.Learning a lot about Plank on frame kits, the Druid instructions are limited, and a lot is lost and is confusing due to language translation!! How are the instructions booklet and plans on the le Requin?
Haven't had much spare time since December should be able to get back to it in few weeks all being wellMany thanks!! How is going your's? It's a long time since you posted an update.![]()
You are absolutely right. These top Chinese kits are so precise that there will hardly be a mistake on the manufacturer's side - well said!and everything is very precise, so if you find something that doesn't fit perfectly, you can be sure that the mistake is your's: almost a relief, isn't it?
I do not think so - it is only the perspective view - I think it wiull be much better and more accurate, when you ley the part directly on top of the area (red lines)My God!!!! Stringers are all wrong!!
This was unexpected, really a bad surprise.
Agree with Uwek Alessandro I remember a lot of filing and sanding for them to fit, you most definitely have the skills to perfect better than I did, it sure is great fun to build good luckI do not think so - it is only the perspective view - I think it wiull be much better and more accurate, when you ley the part directly on top of the area (red lines)
There seems enough meat at the front end (green) where you can adjust to the keel
But most important is the accurate fit with the real model and not the drawing - because every modeler is producing some small inaccuracies - every modeler
I noticed some project differences between your version and mine, isn't by ZHL your's too?Agree with Uwek Alessandro I remember a lot of filing and sanding for them to fit, you most definitely have the skills to perfect better than I did, it sure is great fun to build good luck
Yes it is ZHL I probably misinterpreted some bits and added some things to counteractI noticed some project differences between your version and mine, isn't by ZHL your's too?
I would say there is nothing wrong, instead I've noticed some enhancement well done like the stringers: they should be a little thicker than the deck planks, instead mine are the same.Yes it is ZHL I probably misinterpreted some bits and added some things to counteract
Thank you!Very beautiful work. I'm enjoying your build log.
Pretty sure I used CA glue and heavy weights to fix it AlessandroDeck guide lines for nailing, they are so much and so narrow that I'm getting cross-eyed
The central piece of the deck fits perfectly, that's good.
BTW: gluing this long piece will be a hard task as it has to do a double curve, longitudinal and orthogonal, and there is no room for clamps.
any suggest?
Albeit I hate CA this was my thinking too, thank you.Pretty sure I used CA glue and heavy weights to fix it Alessandro
No problem I just put a spot on each rib end and PVA in-between and clamped with thin long nosed tweezers but I did cut into individual deck planks rather than the whole lot joined together. That way you could use the tweezers against the ribs if helps mateAlbeit I hate CA this was my thinking too, thank you.
