     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
I was born in Vinnytsia...it is a lovely City.Wow! Your set is more complete than mine, but mine is already in a plastic case. The same plant - ЗИЗ (Запорожский инструментальный завод). This set was given to me by a friend of my father. In general, wood carving is an interesting activity, I’ll have to study it more seriously someday.
By the way, this year, in Vinnitsa, there will also be a ship modeling competition. I have already been invited to take part, but, unfortunately, I can’t do it.
Which blackening technique have you applied?One more little thing: I forged and blackened the nails from 0.60 mm steel wire. They will be used in fastening cleats and beams to the sides.
I clamp a steel nail and, using the open flame of a gas torch, heat it red hot. When the nail turned red, I quickly put it in a jar of machine oil. Then it turns out black. Previously, I simply glowed the wire red-hot, without using oil, but in this case the color turns out not black, but rather gray.Which blackening technique have you applied?
An excellent and clean job, the mast caulking has turned out great, and the figurehead is very similar to those of the era. Congratulations, now onto the next one.Finally, I finished the main mast. To be honest, I had to struggle, especially with the basket on top. I succeeded only on the third attempt and by the end I was very annoyed.
To unwind a little, I decided to take a short bike ride, and at the same time discover the cycling season. I went to the nearest exit to the sea, and it was a little more than 26 km there and back.
Thank you Mleonc for appreciating my work.An excellent and clean job, the mast caulking has turned out great, and the figurehead is very similar to those of the era. Congratulations, now onto the next one.
Excellent work, that rigging, wonderful, what wood did you make the masts and peaks from?The spar is ready.View attachment 441232
It was mostly gray beech wood, which I coated with oak alcohol stain. However, my reserves were not enough for everything, so I also used some kind of light porous wood - I don’t know what it’s called.Excellent work, that rigging, wonderful, what wood did you make the masts and peaks from?
it could be elm or popla?It was mostly gray beech wood, which I coated with oak alcohol stain. However, my reserves were not enough for everything, so I also used some kind of light porous wood - I don’t know what it’s called.
Good morning Dave. Lovely work.The little sheaves (I think that’s what they are ) on the end on the spars are so goodThe spar is ready.View attachment 441232
Good morning Grant. I am pleased that you appreciate my work - thanks.Good morning Dave. Lovely work.The little sheaves (I think that’s what they are ) on the end on the spars are so goodas is the support at the base of the mast.Cheers Grant
Model forged from titanium by a master craftsman.View attachment 442873
