messenger cable
  • Thread starter Thread starter Uwek
  • Watchers Watchers 6
I love this way of the messenger @modelshipbuilder65 made on his Royal Caroline in sacle 1:30
i believe its rope too.
someone posted "how anchors are brought up" with some jaw dropping details and documentation of the entire processs. i think i saved it and will post the link.
here ya go... enjoy
someone posted "how anchors are brought up" .....
Time is running - yes I posted it once - I forgot about it
So it was a "normal" rope and definitely no cable - interesting that it is called everywhere "messenger cable"
It's hawser rope.
so a "normal" 3-strands right-handed rope rope
Once I made a screen shot of a video showing in the dark the anchor cable and the messenger of the HMS Victory
hahahaha yes it was you that posted that fact packed thread... i booked marked it because it was so informative. i also sent it to a few friends, not modelers but know it alls, that loved it.
From James Lees Masting and Rigging his drawing shows cable laid rope for the anchor cable but does not show the lay of the messenger. I imagine cable laid rope for the messenger would also be appropriate as you show in post #5
Both the anchor cable and messenger are cable laid rope. From David Steel - cables are ropes made of nine strands that are nine inches and upwards in circumference. Cablets are cable-laid ropes, under nine inches in circumference. From James Lees' The Masting and Rigging of English Ships of War page 188, for the sheet and bower anchors the circumference of the cable is 0.62 X the diameter of the main mast. The circumference of the messenger is 0.75 X the circumference of the main stay. Hope this helps.
Many Thanks for your assistance and the given information
and how a cablet is looking like?
When I read:
it means, that it is cable laid, but only smaller in diameter - but than it would look like the anchor cable only smaller in diameter
and the photo of the Victory messenger shows a cable which is preserved with parceling?
Hallo all - I have a question where I am not 100% sure.
I want to install on my Granado a messenger cable to lift the anchor
Is a "messenger" a cable or a rope?
Technically, I think the Granado should have a Viol cable, not a Messenger cable. I posted this in your excellent informational thread concerning the Granado HERE. I had posted this in your excellent reference topic on the Granado:
As to the answer to your question, I am assuming it is a rope. That does pose the question, however: why is the Viol or Messenger cable not as strong as the Anchor cable?
Yes you are correct with the correct term "viol" and not messenger
The princip is more or less the same, only that the cable is redirected via this viol-block
I made some photos of the Goodwin book, which is showing in some details the model build by Lightley
The viol blocks fixed at the mortar house
The two viol cables are running through these blocks
the anchor cables (blue arrows) are going over the capstan windlass, going down via the main hatch into the hold
the viol cables (green arrows) are turned three or four times around the capstan windlass
And both viol cables are connected with its anchor cable via the nippers
-> so it seems, that in moment, based by this arrangement, both anchors are lifted
So far everything understood ( I think)
But this is not fitting to the anchor arrangement, or?
Unfortunately Goodwin is not showing or describing anything related to this in his anatomy book
I am thinking in moment:
1) How would be the cable arrangement during achorage ?
I guess without the viol-cable and the anchor cable somehow arround a main bitt and fixed with some nippers towards the deck (eyebolts) or something similar
2) During the lifting action I guess like shown in the Lightley model
3) stored anchor during sailing ?
Not so easy when you do not have a "normal" ship .........
I'm not sure what in the above photo is not consistent with the viol-cable system.
That is what I would assume as well.
Yes, I think.
I would expect the anchor cable still to be around the main bitt, in case it broke loose during a storm or something. Probably one or more nippers to eyebolts as well, in preparation for lowering it.
Very true, and the Granado is anything but "normal". I've always wondered about the rope attached to the anchor buoy. Most models I've seen show very little rope coiled between the buoy and the anchor. Yet would it not need sufficient rope for use when the anchor cable is fully extended to its length of 120 fathoms? Current boating anchor standards recommend an anchor scope of 7:1, which means an anchor cable length of 7 times the water depth. But that would still mean an anchor buoy rope approaching 100 feet in length (2 actual feet on our model). That's a lot of rope to coil up! Perhaps they kept the rope short, and added to it if necessary?
