Please consider making a Donation to SOS to support our continuing growth and developement. It is greatly appreciated !!! *** Read More - - Click Here *** https://www.paypal.me/DonateSOS |
Time is running - yes I posted it once - I forgot about itsomeone posted "how anchors are brought up" .....
so a "normal" 3-strands right-handed rope ropeIt's hawser rope.
interesting that it is called everywhere "messenger cable"
it means, that it is cable laid, but only smaller in diameter
Technically, I think the Granado should have a Viol cable, not a Messenger cable. I posted this in your excellent informational thread concerning the Granado HERE. I had posted this in your excellent reference topic on the Granado:Hallo all - I have a question where I am not 100% sure.
I want to install on my Granado a messenger cable to lift the anchor
Is a "messenger" a cable or a rope?
Ah, yes, I guess that is the "retired" part of my being an engineer. Good catch.The messenger only has to lift the anchor and anchor rope. The cable has to be able to stand the forces the ship and tides and wind puts on it.
Yes you are correct with the correct term "viol" and not messengerTechnically, I think the Granado should have a Viol cable, not a Messenger cable. I posted this in your excellent informational thread concerning the Granado HERE. I had posted this in your excellent reference topic on the Granado:
As to the answer to your question, I am assuming it is a rope. That does pose the question, however: why is the Viol or Messenger cable not as strong as thecable?
you see at the sketch posted by @SignetIs the viol only used with a windlass and the messenger only used with a capstan? Or is that too generalized?
I'm not sure what in the above photo is not consistent with the viol-cable system.
That is what I would assume as well.Unfortunately Goodwin is not showing or describing anything related to this in his anatomy book
I am thinking in moment:
1) How would be the cable arrangement during achorage ?
I guess without the viol-cable and the anchor cable somehow arround a main bitt and fixed with some nippers towards the deck (eyebolts) or something similar
Yes, I think.2) During the lifting action I guess like shown in the Lightley model
I would expect the anchor cable still to be around the main bitt, in case it broke loose during a storm or something. Probably one or more nippers to eyebolts as well, in preparation for lowering it.3) stored anchor during sailing ?
Very true, and the Granado is anything but "normal". I've always wondered about the rope attached to the anchor buoy. Most models I've seen show very little rope coiled between the buoy and the anchor. Yet would it not need sufficient rope for use when the anchor cable is fully extended to its length of 120 fathoms? Current boating anchor standards recommend an anchor scope of 7:1, which means an anchor cable length of 7 times the water depth. But that would still mean an anchor buoy rope approaching 100 feet in length (2 actual feet on our model). That's a lot of rope to coil up! Perhaps they kept the rope short, and added to it if necessary?Not so easy when you do not have a "normal" ship .........
