Any building today will be with PVA. Thankfully I had some Benadryl in the house which got me through the night. I'm amazed at how quickly the watery eyes, runny nose and breathing difficulties came on.
**VIEW THREAD HERE** |
Sorry about your problems with the CA. The stuff is methyl 2-cyanoacrylate. Recommendations for respiratory protection specify a full face respirator with organic paper (OV) cartridges. I assume that the reason for a full face respirator is to eliminate eye exposure. I have sometimes noticed some minor stinging of my eyes when using CA. Since full face respirators can be annoying to work in, you might want to try a half face with OV cartridges and see if that works for you. Fair winds!will try a face mask.
PaulHi Ron, see my post #43 above for a possible solution to your new allergy problem...or maybe you already saw it?
A nice result of the planking, Ron. It show her liner very well.Well after my bout with CA allergies, my Sciatic nerve rearing its ugly head I finally finished the 2nd planking of the hull. Of course deviating from my normal practice and taking shortcuts got me into trouble. I normally fill between all bulkheads with balsa to give me a nice continuous surface for gluing. This time I just filled areas of the bow and stern. Ugh! Also as my intent is to paint below the waterline I wasn't quite as fussy with my planking below the paint line. Another shortcut regretted. In between planking the hull I started assembling some of the deck features. (makes one feel he is accomplishing something) Nothing glued in place as yet. Hindsight tells me that if I were to do it all over I would have filled between all bulkheads and not applied the first layer.
Thanks Peter,A nice result of the planking, Ron. It show her liner very well.
Good afternoon Ron. That planking is fantastic. BTW I Love the font variationWell, that worked out better than I expected. I cut four sets of spacers (The rails are all spaced different from each other)from 1/32 ply with my Wonder Cutter (Ultrasonic cutter) clamped the spacers to the hull and laid the rub rail along the spacer. Didn't really need to clamp the rail as with the large bow in the hull they lie flat against the hull while the glue sets. Two down and two to go. (+ the other side.)
I first tried cutting the ply spacers with my Xacto knife however, the blade tended to follow the grain of the wood. Remembered I had purchased my Wonder Cutter months ago and it cuts like a hot knife through butter. Nice smooth cut following my pencil line. The only downside to the cutter is that it leaves a char linebut I guess we're all used to char. At least I didn't have to remove it.
Now if I could just figure out why the font size changes when I preview and post
That’s looking nice, Ron. Perhaps like a lot of other models, paint just one side?Rub rails on one side. After the other side it's time to mask off and paint below the waterline. If I hadn't done such a sloppy job of planking below the line I may have considered not painting. I dislike painting over nice wood, oh well.
Good morning Ron. Looking good. Ahh that sciatica nerve….horrid pain. I had that at the beginning of the year (resurrected an old injury) and was not pleasant . Electro acupuncture sorted it for me. Good luck. Cheers GrantWell, got all the rub rails installed however, I'll have to put off painting for a while and work topside. Can't seem to stand very long with my nerve issue. Was handy to have all the timberheads to clamp onto and maintain alignment with the bulwarks. For down pressure I nipped a section out of the plastic clamps to extend over the rail and provide downward pressure.
I can really relate to your situation. About 2 years ago I couldn't sit for 5 minutes. Walking was the only thing that brought relief. Even during meals.Ahh that sciatica nerve….horrid pain.
