Good morning Rob. I just learnt something new- I never heard of a deadeye claw- now I know. It all these details which make for a fine model- nice. Cheers GrantThe deadeye claw was used to set the distance to the other deadeye on the shroud.
The shroud was wrapped around the other deadeye, held in place by a dab of UV glue.
Thank you Grant, This deadeye claw is a good way (at least for me) to set the distances to be equal between shroud lines. I will know for sure when I, hopefully, am able to tie the lower and upper deadeyes together.Good morning Rob. I just learnt something new- I never heard of a deadeye claw- now I know. It all these details which make for a fine model- nice. Cheers Grant
Good morning Rob. You attention to detail on this boat is commendable and certainly has added to this model. Those hooks. I would try make them smaller if you can.The hooks were then passed through the excess wire, the wire twisted and the excess trimmed away.
Love the last pic-Well the first time I have laced deadeyes together. I have done 4 so far, these are the first 2. I think by the time I get to 100 of them I will have it down!
For some reason, even using the deadeye claw to keep the distance the same, the lenghts of th lashings on one side are longer than the other side. At least the shrouds appear to be under tension and straight.
Roger I agree entirely with what you say. This is actually mentioned in the instructions.I’m a new member of SOS so missed Alan’s comments about the mainsheet horse aka traveler. The forces affecting a sailboat are the same today as they were in the 1700’s so the physics of sailing a boat today are the same.
These boats were equipped with a large powerful mainsail. With the tiller swinging over the traveler it would have fouled the mainsheet every time the boat tacked. In anything other than a near dead calm moving the mainsheet around the foreword end of the tiller while tacking would have been impossible.
I have sailed on dozens of different sail boats from a Sunfish to a 40’ Screamer. When a boat tacks it is vulnerable because without forward motion the force vectors are broadside and “over she goes!.” I have the capsizes to prove this.
I cannot explain decisively why the traveler on the Medford model is arranged as it is but I suspect that sometime during its long life, the model was rerigged by someone who was not a sailor.
Roger
You are right Grant, I was not happy with the hooks I will try to make them smaller.Good morning Rob. You attention to detail on this boat is commendable and certainly has added to this model. Those hooks. I would try make them smaller if you can.
Love the last pic-
Cheers Grant
