3d printing
Your 3D printer is a filament printer, which prints up in layers of solid material, and one of two major types commonly in use, I have the other style, a resin printer, which prints with light in a bath of resin.
Yes as you have said, learning the tricks, tip and in's-out's of 3D printing takes a while, and the software is something that takes a while to get used to how it all works.
I think your right about the need to have a separate section set up and maybe a files sharing area to go with if if at all possible.
I agree, there are a lot of 3d information and file sharing sites but very little information related to ships.
I 3d printing group would be nice where you can get advice and one on one help as well as file sharing. Maybe even some modeling help.
Here are some of the parts I have printed for my 1 Meter RC boat.20240811_110903.jpg
You'll never get "fine" detail with a filament printer because the layers are significantly thicker than a resin printer lays down. Most folks here are working is smaller scales than I am, and for carvings, guns, wheels, figures, anchors, and all the details 3D printing can provide, filament can't come close to resin in that regard.
It's good for printing hulls and bigger stuff where detail isn't an issue, and even then it requires some level of "finishing" like sanding and filling you don't usually need to do to resin part.
A 10 inch Dahlgren pivot gun...
Period drawing
3D model
Resin printed 1:36 scale model partially painted
If this is a sample of resin printing for sure filament printing cant hold a candle to this. I could never get this quality with my printer.
resin printing is the way to go for precise and detailed prints. I am currently working on a 1/64 bluenose from plans from m.s. and am finding the savings from printing over purchasing over priced fittings (often in an incorrect scale) to be huge. anything from turnbuckles to air vent funnels can be printed for pennies. i know that some of the "old school" builders here look at 3d printing the way i look at rap music, but its the old saying "don't knock it till you've tried it".
May I ask how big the resin printer is? How many segments in the hull?
A Mighty 4K. Fourteen hull sections in all.
Using the base 637 class 3D design I generated, (all from USN documents and photos) allows printing of any version of Sturgeon-class submarine using different sails and a "plug" for the long-hull version. I have an extensive 1/72 library of common masts and antennas since there were different types installed in each class during a submarine's life, and each sail cap reflects the different configurations applicable to the time period.
1/72 is a great scale to showcase a model, but the extra detailing included at this size requires extensive research before the design process begins to ensure the highest degree of accuracy, since the larger the scale, the easier it is to notice inaccuracies.
I need to swap out the screw from a seven to an eighteen-blader before the decals arrive, and the next painting phase begins.
Very nice detail indeed. Thanks
Thank you! I'll post more when it's further along. The Type 8 Observation scope shown above has since been replaced by the newer version which includes PeriViz, the first standardized observation periscope video system, it includes its ESM suite in a dome, whereas the Type 8 above uses a stub antenna. I've included a render I made of the 3D model, which is another benefit of CAD - visualization during the build process. Useful when pattern-matching against reference photos in the background to ensure proportional accuracy when measurements aren't available.
A cautionary note from me - in principle the savings should be huge but there is a relationship between your skill level at both designing and printing, and the cost. If I'm honest with myself (and as a realist, I usually am), the volume of resin and filament in my scrap bin far, far outweighs the volume that has made it on to a model or project and I could have bought all the aftermarket bits many times over, and then some, with the amount of money I've spent on 3D stuff. But would I change this? Not really. I enjoy the problem solving too much, and the (probably futile) quest for perfection.
i just changed my bed to glass. and did the sheet of paper thing to get the right height for the nozzle. CHanging the bed to glass was probably overkill, but I was tired of messing about with the filament sticking to the bed.
Jack, I did the same thing. I have also found that bed temperature also makes a big difference as well. One tip while using glass is to let the bed temperature cool down before removing the part.
I'll second that - I have a divot on what is now the underside of my glass plate from when I didn't wait. Once it's cooled, the parts have often self-separated. Just to reiterate, use 3DLAC if you can get hold of it. Much better than tape, pritt stick etc. While I'm doing product promotion, can I recommend AnyCubic silk PLA filament. I'm making a 3D printed pendulum clock at the moment, and this filament really is the business. The layers in the photo are 0.2 deep x 0.4 wide, using a 0.4 nozzle, on an ender3 pro. In contrast to various other brands that I've used, there is virtually zero stringing, bed and layer adhesion is exactly as you'd wish, and all dozen or so gears have printed beautifully. The one in the photo is about 50mm OD and I'm especially impressed with how it's handled the 8mm spindle. I'm mentioning this because I've never before been able to find a filament that was clearly head and shoulders better than the competition. Even big name, highly reputable makes have seemed little different to a random, cheap chinese brand. But I'm impressed enough with this to want to check out other FDM products in their stable. (For balance, I really didn't like their standard resin, think I still have a half-bottle somewhere).
I recognize that gear! Or one very, very much like it! An entire family of them are keeping perfect time on the wall behind me as I type.
Your comment about not all filaments in a manufacturers line working the same is quite true'
I am a big fan of resin products but...I cannot paint.
i think there are different colors available so cannons can be printed in black. i know there is a huge variety of colors available in filament not sure with resin printing. So you do not have to paint them
Printing black and not painting is not a good idea. The print has a shine, and this is bad. I paint with a spray can of matte paint based on acrylics. I describe the whole process of modeling, printing and painting in my build thread.
Steve Peterson clock? I'm enjoying this little project, I've wanted to make a clock for years but didn't really know where to begin. For anyone interested, Steve's clocks are a classy bit of 3D printing design, well worth a look and not that expensive
Agree, but more because the painting protects the prints from further UV exposure, which makes them more brittle.
For the OP: I'm not that good at painting either, which is why I generally try to design things so that each part only has one colour. I can then airbrush each part and usually get a decent result.
Yes, that is the place. I have printed 4 so far. One works very reliably (32 day with the side pendulum), the smaller version of that that worked for 7 weeks and then stopped for some reason and I haven't tinkered with it, the Moon Phase one that is waiting for assembly and the Coupe Purdu one that is waiting for parts and then assembly.
i figured i would try printing cannons i started with the smallest and if i could print it with an Ender filament printer larger sizes would be no problem
here is the result.
when you zoom in really close the finer details are distorted and it looks a bit rough
looking at a screen shot of the original cad drawing you can see the sharp detailing
i uploaded the object file for anyone wanting to test a print and see if they get better results
Should I save this as a .stl file?
Yes, save 3d drawing as an .stl file. I believe all 3d printer slicer programs read the .stl file.
One side comment. If you're going to 3d print it's best to do cannon using liquid resin 3d printers. You can try filament printing, but you'll find the accuracy of that method as unsatisfactory.
creating an object is so much easier than 3D sculpting and here is a get started in 3D modeling and printing
it is a cannon at fort Maldon in Canada
I did a screen capture of this cannon and then used that image to create an STL. Easy peasy! It's not 100% faithful and can be taken into Fusion 360 or the like for further editing. The program is called MESHY.AI - and uses AI to create images from pictures or even from print. I prefer the resin (SLA) 3d printer because it produces much much greated detail than filament (FDM) printers but is limited in size of print. For larger items, the model is typically cut into pieces and then reassembled after printing. 2025-01-21 (1).png
