Thanks Peter, that is a good description for this project.It looks ‘complex in it’s simplicity’.
Looking good Daniel.Hello all, I wanted to show progress on the engine assembly. One of the Wright brothers' employees named Charles Tayler designed and hand crafted a horizontal cast aluminum block with 4 cylinders. The engine weighed 170 pounds and produced 12 HP. So far I have installed 4 ignition heads powered by a magneto (no spark plugs). They used a camshaft system to deliver electrical charges to the ingnition heads. Installed the ignition cam and the exhaust cam and intake valve stems. You can also see the rocker arms and their construction.
View attachment 472466View attachment 472467View attachment 472468
Next you can see the ignition cam followers and the ignition terminal strip. Per the instructions I hand bent the strip to match the little port holes, drilled into the port holes and attached the strip glue them in place.
View attachment 472469View attachment 472470
Again, here is a photo of the look I am after.
Hope you all enjoy, till next time have a great day.
Hello Smithy, welcome aboard. I have let more than a few curse words fly during this build due to my clumsiness.Fragile is definitely the first word that came to my mind. I would be nervous just bringing my clumsy self into the same room as a model like this.
You seem well able to cope with it though. I look forward to seeing it completed.
Definite improvement!I felt the need to make an adjustment to the wiring on the Flyers engine. Looking at my macro shots highlights a lot of scuffs and dust. I think what follows better represents the wiring, see what you think. I also darkened the body of the magneto.
Old way New way
View attachment 472898 View attachment 472899
Hi Shota! Glad you found my build.my dear friend Daniel
I missed your amazing progress , well done
A really exceptional modeler would get a clamp on that hoseAs far as the engine plumbing goes, I neglected to connect a lower radiator hose to the provided nipple coming off the bottom side of the crankcase, naturally after I had glued and nailed down the block thus severely limiting access. I wanted to show my solution to this plumbing problem. First, I made a wire template with the necessary bends and lengths, then with the largest brass tubing I had, fashioned the piece that would get me out from under the crankcase. The rubber tubing provided is too big in diameter, so I was able to slide it into some brass tubing, very briefly hit with my torch and it shrunk like a glove onto the tubing. glueing the fabricated piece into the tube and ready for installation.
View attachment 473508View attachment 473509
After some careful insertion (winding around, holding with helper tools) was able to fit the open end onto the protruding nub and glue in place. WHEW!! didn't break any of the delicate rocker arms or other underside fittings.
View attachment 473512View attachment 473513
I got lucky on this oversight.
For the rest of this build I will have to have the top wing in place which cuts way down on easy access so here we go.
Thanks for looking in.
I do appreciate the suggestions regarding the use of hose clamps however it appears that the pressures involved did not require their use as depicted in this photo.A small flat string would work good for makeshift clamp on this install, or paint of silver if that talented like Doc K with tiny brushes.
I wouldn’t trust the rebuild. They probably forgot to install the hose before the engine was put into its final place.I do appreciate the suggestions regarding the use of hose clamps however it appears that the pressures involved did not require their use as depicted in this photo.
Yea, they wouldn't want me near it.They probably forgot to install the hose before the engine was put into its final place.
A very convincing representation of that aero engine, taking your time to get the finish right is paying dividends.Hello all, I wanted to show progress on the engine assembly. One of the Wright brothers' employees named Charles Tayler designed and hand crafted a horizontal cast aluminum block with 4 cylinders. The engine weighed 170 pounds and produced 12 HP. So far I have installed 4 ignition heads powered by a magneto (no spark plugs). They used a camshaft system to deliver electrical charges to the ingnition heads. Installed the ignition cam and the exhaust cam and intake valve stems. You can also see the rocker arms and their construction.
I started using this very same method to locate some of my parts and assemblies. Great minds...If you look closely at the engine feet you can see where I drilled holes and inserted a small nail with CA so it's very secure.
Thank you Johan.A very convincing representation of that aero engine, taking your time to get the finish right is paying dividends.
