Wright Brothers "Flyer" 1903
I have now set the chain drive assembly which took me all day yesterday. The toughest part was setting the chains themselves onto the gears, man unbelievable how difficult it was. In hindsight I would have done a better job of preparing a receiving depression on the ends of the chain supports. Here is the assembly. In subsequent photos you will see where I tightened the chain up some.
Next, I began installation of the Wing Warping Pulleys and wire. The gray rope is supposed to represent steel wire, and at every pulley they used chain to ride over the rollers in the pullys.
Quite often I get caught up in the macro shots and neglect the overall shots.
Hope you enjoy and thanks for checking in.
View attachment 474421View attachment 474423
View attachment 474424View attachment 474425View attachment 474426View attachment 474427
Good morning Daniel. Lovely detail. Patience personified. Cheers Grant
Its amazing what an odd aircraft this was, with an offset motor and no ailerons on the wings. But it was a prototype and a big learning curve. ;)
Can you imagine the noise that thing makes with those chains moving quite rapidly through the tubing guides.
I've moved into the next phase of my build, the rigging cross bracing of the wings. I set all the vertical struts which went well. Set the wing warping leads (just loose for now) which is 0.6mm line and began work on the 0.43mm cross brace lines.
This is the look I am after.
This is what I've come up with. 1.50mm OD brass tubing x 6mm long painted silver with 0.43mm line looped into it. I'm relieved I don't have to try and hand seize 36 plus of these connections.
Till next time have a great time!
View attachment 474607View attachment 474608
Dear Daniel
Thanks to your beautiful work, I get to travel in time
