Titanic Trumpeter 1/200 by InkMot
This is a log of my progress with the Trumpeter Titanic. I know that there are many of these and I appreciate your patience with my contribution. My hope is to share the things I’m learning about the kit along the way, including my experiences with the third-party detail kits. Every project should have a goal. My goal for this build is to create an accurate impression of the ship as she departed on her maiden voyage. I define accurate as that which would seem obvious to an observer who’s familiar with the ship from about 2 feet (.6 meters) away, avoiding the addition of such things as photo-etched brass when I feel its inclusion would actually detract from realism, e.g. I’ll show you why I swapped out the Minibrass stern plating in favor of .13mm styrene. I’m not sure I’ll want the model to be lit up, which may also mean that I won’t spend too much time on interior spaces. I’ll wait to see what is observable from 2 feet away. I’m not building a dollhouse.
Thanks for your interest so far.
This is what I began with: A Christmas gift from my wife in December 2021. It went on the shelf while I completed a 1/80 scale, launch-able Saturn V rocket kit - which I’m now too afraid to launch. ;-)
Hallo @InkMot
Hello everyone,
I tried a few days ago to order a figurehead for a 1/200 Victory from Shapeways because the one that Caldercraft provides in their kit is not even to consider. But... just heard from Ben from MidwestModelShop that Shapeways went bankrupt. Now I'm looking where to find the stuff that was offered on their site. I also tried to order several items for my Trumpeter RMS Titanic. I build both models simultaneously. I have bought almost all of the parts that Woody's offers on his site, but still looking for more parts to enhance my models. Anyway the Figurehead for the HMS Victory is the most important for now because the thin one provided from Caldercraft really looks like a peace of cr... Sorry.
Thanks for any response. Daniel
7. Correcting and installing the propeller wave wings
8. Bilge Keels:
I’m catching up on some progress since March, so stand by for several posts. ;-)
I did some minor modifications to the propeller wing busses. This was mostly etching the aft edges to shape them more into a taper. I also etched in the end of the plates. If you look at the photo below, you can see how the pates end and how the trailing edge of the propeller buss tapers.
I did not attempt to simulate how the plating curves to meet the hull, opting instead to just fill this with putty and move on. Another difference between the kit parts and the actual ship is the direction of the plating on the surface. The real plating ran parallel to the side of the hull, while the plating on the kit parts run parallel to the propeller shaft. I’ve come to accept that there are details that I notice but few others will care about and I’ve chosen to look past them in favor of finishing this project in a reasonable amount of time.
This image shows the etching work on the trailing edge of the propeller buss and the tapering on the trailing edge. You can also see where I’ve filled in and shaped the joint to simulate the curves on the real ship.
Here are two views of the completed and primered stern area. Note that I also added the pad eyes on the stern plates that were used for attaching block and tackle for propeller maintenance. These were PE parts that were incredibly tiny. Several have been knocked off during construction or lost during assembly.. I’ll need to come back later to repair these.
Another addition has been the bilge keels from Model Shapeways. I forgot to take photos of this process. If you’re planning to replace the kit bilge keels with the available 3D printed versions like I did, or if you’re just planning to make your own out of styrene, I’d suggest waiting until you’re about to paint the hull before putting them on. Otherwise, you’ll keep knocking them off. Ask me how I know. ;-)
Since I’m not sure if I mentioned this previously, note that the rudder is a replacement 3D-printed part from Shapeways.
Next Steps:
  • Drilling portholes
  • Painting the Hull
Great job that I will follow sinds I also started up a Trumpeter Titanic. Already ordered some Maritime model, AK and MiniBrass stuff. The only problem seems to be finding a hawse pipe. ShapeWays does not exist any longer… If somebody has a idea where to find it!
I also received stuff from Andrew 3D to strengthen the hull and in the meantime offers a base for the light kit from Magic Scale Modeling. Great enhancements.
Kind regards to all,
Daniel
Drilling Portholes:
I had ambitions to add the MiniBrass plating sections for B and C Decks. I purchased it…and then decided that I didn’t want to do major surgery again on the hull for what would be a subtle change. For any project to get done, scope must be managed. Here’s what that kit looked like before I sold it:
I opted instead to purchase the Scale Warship PE porthole inserts and to not worry if some portholes were in the wrong place or non existent on the real ship. Nobody is going to notice.
Here are the Scale Warship porthole frames. The kit comes with replacement gangway doors (you can do open or closed) and it includes porthole glass.
Before you drill your portholes, ask yourself this question: Why? ;)
Seriously. it’s a ton of work. There’s around a thousand portholes on this hull, give or take. It’s going to take you a long time. If you’re planning on lighting the kit then go ahead and drill. If not, may I suggest that you just fill each porthole with either a drop of clear gloss or Kristal Klear after you’re done painting?
Anyway, about drilling portholes…
To drill the portholes, I purchased a number of excellent drill bits from Drillbits Unlimited. (https://drillbitsunlimited.com). These guys are great! They were prompt with answering questions, quick in shipping and their pricing is reasonable.
Here is the set of drills I purchased for my project. I suggest that you decide how you plan to glaze your portholes BEFORE you purchase your drills. If you’re planning to use fiber optic, as demonstrated by the Midwest Model Shop, make sure you buy drills to accommodate the limited selection of fiber optic diameters. I made the mistake of measuring each molded porthole size with a micrometer and then ordering my drills for each measured size. The result was that the fiber optic sizes used by the Midwest Model Shop would not fit all of the holes I drilled. I ended up going with a mix of fiber optic and Kristal Klear (more on this in a later post). I was not going to re-drill a ton of holes.
To drill the holes, I purchased the Tamaya Drill. This is an actual kit that you have to assemble. It cost about $35, but it does an excellent job drilling portholes. You could also use a pin vice, but I don’t think you could fit drills like the ones I purchased in a pin vise. Also, your hand is going to hurt a lot. Do not attempt to use a Dremel tool for this, unless you like big burn holes in your hull.
Here’s a shot of the hull in mid-hole drill. Note that my aftermarket bilge keels are mounted on the hull. If I’m ever stupid enough to build this kit again, I’ll mount those bilge keels just before I paint the hull. They’re fragile and they break easily. BTW, you can make realistic bilge keels with strips of thin styrene and save yourself a bit of money.
I’ll cover the mounting of the Scale Warship porthole frames in a later post, since they get installed after you paint the hull.
Painting The Hull:
After drilling portholes, I spent a lot of time prepping the hull. This included filling a lot of gaps in the MiniBrass hull plates on the bow, bottom of the hull and also the stern plating. I spot-primered critical areas to reveal any issues and went back and forth with putty, sanding and priming. I won’t bore you with all of the details, suffice to say that there were many iterations as I looked to minimize blemishes.
The hull was given an overall coating of grey primer to prepare for color.
I was originally going to use an airbrush to paint the base layer but opted for the ‘ol trusty “rattle can”. I like to soak spray cans in warm water for a while and give them several rounds of shaking. This helps with a smooth coat.
I went with a semi-gloss. This gives a nice sheen. I know some prefer everything to be flat, claiming that gloss paint looks flat at a distance and that this creates a sense of scale. I don’t disagree, however, I feel that 100% flat is unrealistic for a commercial ocean liner as well. I’ve had success with semi-gloss on LARGE models.
Using an airbrush, I added variations and weathering to the black hull paint, using Floquil Engine Black (Flat) and Tester’s Semi-Gloss Black. The Floquil Engine Black has an interesting bluish-black look that I liked. I worked mostly in virtual motions to simulate the effect of many days of rain, etc. draining down the sides of the hull.
After painting the hull black, I needed to mark the line for the anti-fouling. It’s not a straight line for the Olympic Class ships. It curves up a bit on the bow and stern. I did start with a straight pencil line using a jig and a large, flat surface (kitchen island counter).
The Midwest Model Shop has a great YouTube video describing this process. I highly recommend it.
Here’s a shot of the hull painted with a base layer of Krylon Matte Red Pepper. I then used an airbrush to add some accents of Floquil Tuscan Red to knock down the color and provide a bit of weathering.
This picture will give you an idea of the weathering effects. Note the darker vertical streaks on the anti-fouling and the variation in the hull black.
Here is the hull, with the hull black and anti-fouling and initial weathering.
The next step was to add the zinc yellow accent stripe. Vallejo sells a Titanic paint kit that has this. I didn’t have it at the time, so I mixed my own using drops of green added to yellow:
Painting the yellow stripe before I painted the white worked out well.
(Oh look! The rudder got knocked off…again.)
The last step was to paint the white upper part of the hull. I used Tamaya Flat White with a semi-gloss clear coating. Having the yellow stripe already painted made it easy to mask over top of it to create the needed white areas. I’ve seen the yellow stripe added last before and I watched the modeler struggle to keep things neat.
A view of the starboard bow, showing the name decals in place. I like how all of the work I put into the haws pipe upgrade and surrounding plating came out. I skipped a step here and didn’t spray that area with gloss before applying the decal, so I’ll end up re-doing that later.
Another lesson-learned is to paint the inside of the haws pipe before painting the hull. It won’t be a big deal to squeeze some red in there later, but it would’ve ended up looking better had I sprayed that area first and then masked it off. Also, note the PE railings just at the bow. These tend to get knocked off, as well as some of the other PE items such as the shackles on the stern (used for servicing the propellers). It might be best to add these last, if you’re planning on using such PE parts.
Stern view. I have since touched up the yellow stripe and added the “TITANIC LIVERPOOL” lettering on the stern. The anti-fouling appears very red here. It’s since been knocked down with Floquil Tuscan Red and highlights have been dry brushed on using the Anti-Fouling Red (Pink) that is included in the Vallejo Titanic Paint Kit. BTW, that Shapeways rudder has been re-attached about a dozen times so far. ;)
Here’s the overall view of the painted hull.
Just catching up on the progress of my work. I'm finally done with the hull and have moved on to the forecastle, poop deck, well decks and superstructure.
A big part of completing the hull was glazing the portholes. This was done with a combination of Kristal Klear and fiber optic.. Kristal Klear peformed surprisingly well for the smaller portholes and for the windows on the gangway doors. It also an easier solution than using fiber optic for all portholes or installing plastic plugs or disks.
409BFB85-83D1-4F47-9E75-55550B337D94_1_105_c.jpeg631275E0-AD46-4BA7-B480-12937D0E4038_1_105_c.jpeg
BA948338-9343-4E9E-96B8-9BA8914F8FFD_1_105_c.jpegC5482887-0289-4147-A2DC-ADD5BD888DD2_1_105_c.jpeg
Modifying B and C Deck Superstructure
Since I’m installing the Woody’s Model Works A&B Deck and Bridge kit, I needed to modify the B and C Deck Superstructure provided by the kit. This involves sawing off the B Deck Prominade and shaving the width of the upper edge to allow the brass plating from Woody’s to be plumb. This requires some careful measuring with a micrometer to get the cuts right. All of this is provided in the instructions from Woody’s Model Works and also illustrated in a good video from The Midwestern Model Shop.
After making the modifications, I drilled out the portholes, removed and replaced the extremely thick supports at each end of the promenade and painted. Finally, I inserted plastic lenses and PE Utley porthole frames.
Cutting and Smoothing the Superstructure
Shaving and smoothing the top edge. Note the use of clamps. Later on, I added strips of wood to stabilize the the superstructure. I recommend you do this as well.
I used a cutting wheel and my Dremel tool to saw off the B Deck promenade. This makes a mess of melted plastic that you’ll have to carve off. I then used a small plane that I purchased at Lowe’s for about $17 to smooth down the top edge and to thin out the sides to spec. Getting this plane really made the work easier and provided a satisfactory result. I learned this tip from The Midwest Model Shop.
I used the plan to thin out the width of the superstructure to allow the Woody’s Model Works PE to be plumb. The plates from Woody’s extend from B Deck to A deck (I think). Anyway, the widths of both decks are different and you’ll need to thin out this part to ensure that the outside part of the promenade isn’t tiling in. (BTW, sorry about the rotated image. I’ve wrestled with it and given up.)
I kept working until the width was 1.3mm. Note the use of the wood strips for stabilization. (Again, sorry for the rotated image. )
Adding Utley Porthole Frames to Larger Portholes on Superstructure and Hull
After I completed my cutting and shaving, I went to work drilling out the portholes. I use the Tamiya drill and drills from Drill Bits Unlimited for this tedious work. Please see my previous posting on drilling portholes for details. The portholes on this deck have the Utley frames, similar to the lower deck in the hull, only the Utley frames installed in the hull are black and the superstructure frames are white. I used a PE kit from Scale Warships (https://scalewarship.com/index.php?route=product/product&path=365_372&product_id=1533) for this. The kit comes with the frames and acrylic porthole lenses. They also include gangway doors, if you’re so inclined.
Scale Warship Utley porthole frames that have been sprayed white. Notice the missing frames that were previously painted black and inserted in the hull.
D-Deck / Hull Utley Portholes:
These were drilled with a 3mm drill. I used 3mm fiber optic sections for the porthole lenses which were cut in a half inch lengths using side cutters and sanded on one end to polish them. I used 220, 320 and 600 grit sand paper to finish the edges. Each fiber optic section was inserted from inside and glued with Tamiya extra thin. I left a couple of mm of space to insert the Utley PE frames, painted black, on top. NOTE: It’s best to use a wax jewler’s pencil to handle the small PE Utley frames. A drop of CA will hold them in place.
C-Deck Utley Portholes:
The upper deck Utley portholes were drilled the same way. I used the acrylic porthole lenses that came with the Scale Warship kit for these, mainly because it’s easier to access the holes and insert them on the superstructure than it is in the hull. The wax pencil was the hero again here as i worked to insert the PE Utley frames. I found that allowing a shallower depth for the lens helped with positioning the Utley frames. There will be a seam around the frames that I’ve filled a bit with a bead of white paint, but more or less left alone.
Utley frames and porthole lenses in progress. The lenses on this side were set a bit deeper than ideal. I made them shallower for the other side and it made inserting and aligning easier.
Promenade Deck Supports
My goodness the stock ones are HUGE! This was going to be a problem since the PE superstructure from Woody’s has supports for the promenade deck above that are to scale. I removed each one with side cutters and made new ones using .13mm styrene. I cut a strip that was about 2mm wide and doubled it up, gluing it together with Tamiya Extra Thin. You can see the difference below:
This picture shows the doubled strip of .13mm styrene that I made and the old supports that were removed. You can also see some of the new supports in place.
New supports on the left, old on the right.
Old supports on the left, new on the right. NOTE: The reflection from strips of acetate that have been glued to the back of the superstructure to glaze the promenade windows. I’ve done this in several areas.
Lesson Learned:
Wait until after you’ve installed your superstructure on the hull and after B Deck is in place to install your thinner promenade supports. The process of wrestling and clamping the superstructure and decks together tends to knock the delicate supports off. I plan to replace a few after I’m finished with the superstructure work.
Lesson Learned:
Good pointers! I installed the bridge step ups, and realized after that it needs waiting till after on the superstructure!
Currently on my first sanding of the fibre optics... It'll be a while.... my fingers are sore from the first 50 or so...
I didn’t use the fiber optics for everything. Mainly because I realized that I purchased drills based on the sizes of the molded portholes instead of the diameters of existing fiber optics. ;) Switching to Micro Kristal Clear to fill the portholes made my life easier and I’m pleased with the results.
Lesson Learned:
Love the work, and that particular upgrade. Hadn't thought of it, but will now attempt the same.
Well Decks, Forecastle and Poop Decks
The wooden decking was laid on after sanding the molded deck off and removing all surface items. I glue the decks on following the process I learned from The Midwest Model Shop: Attach the decking to dark tissue paper first and then glue to the plastic deck with wood glue. It’s supposed to give you longer adhesion over the long run and it allows you to adjust the position of the deck while installing, which I think is the biggest benefit. I’ve also begun spraying the plastic deck surfaces in black in other areas. This, combined with the dark tissue paper simulates the tar that was put between planks and also the water ways.
I will install the brass waterways on the forecastle and poop decks later.
NOTE: I don’t know why the ships of scale forums are rotating my photos. I’ve given up messing with them to straighten them out. If you know why, please tell me. Meanwhile, sorry for making you turn your head .
I’ve sprayed all of the deck hardware that is to be black a dark grey instead. I think this provides a more scale look.
Here the 3D printed parts are sprayed together. I can touch up later.
Anchor windlasses and winches set in place but not glued. I’ll install these much later on so that they don’t get damaged during the deck construction.
The color for the well decks was mixed to match the color swatch provided by the kit. I’ve used Faded Yellow and Anti Fouling Red from the Vallejo Titanic paint kit in ratios that I no longer recall. Anyway, pro tip: paint first, lay decks down later (notice the blue masking tape?).
Well Decks
Shot of the aft well deck, looking forward. The poop deck is in place.
Aft well deck looking aft. Ventilators and supports have been installed, but I’ve left much of the other details for later on. The concern as always is knocking off details as you move on to the upper decks amidships. My plan is to return to the well decks and forecastle and poop deck areas after the model has been mounted on it’s permanent stand and after structures on the Boat deck are in place.
