Brian are using PVA glue to assemble all wooden parts of the model or do you also use Ciano for some wood parts?
Cheers.
Hi Brito,
I use Titebond glue and cyanoacrylate.
Cheers.
Thank you for your reply Brian ! I will hopefully get on with my build this next weekend after a month working at sea. Lots of frames ahead! My jig came with some laser cutting defects but i think i can solve it with the smaller jig for the first bow frames. Check it out and from your experience give me your opinion on my solution toughts given the defect area of the jig. Do you think its doable with the smaller jig and will not disturb the final position of the frames?Hi Brito,
Hi Brito,Thank you for your reply Brian ! I will hopefully get on with my build this next weekend after a month working at sea. Lots of frames ahead! My jig came with some laser cutting defects but i think i can solve it with the smaller jig for the first bow frames. Check it out and from your experience give me your opinion on my solution toughts given the defect area of the jig. Do you think its doable with the smaller jig and will not disturb the final position of the frames?
On the pictures you can notice the cutting error i refer too. Mainly on "S12" they don't even get close together and there are other defects that will affect the frames positioning..
Thank you for your opinion and help.
Hi Brito,
Where can we find your build log? It is lots of fun to do it.
Hi Brito,
Your framing jig looks the same as mine and was wrought with difficulties trying to make it all fit together. I ended up cutting into it and made adjustments as I went along fitting the frames.
As soon as I was able, I discarded the framing jig and now have the hull on my own basic jig, held straight by the keel with small 90 degree aluminium angle lengths.
Hallo @Brito_686 , I agree here with the idea of Maarten - would be great to see your built - highly interested![]()
G'day Uwe maarten and everyone else.Hallo @Brito_686 , I agree here with the idea of Maarten - would be great to see your built - highly interested![]()
The wood of the planks is looking very good - good choicePutting my new planking clamp to good use.
View attachment 57460s to good use.
First of all do not buy black paper. The commercial black paper is too refined and not suitable, as it does not allow the glue to penetrate through the pours of the paper properly..
You need brown paper similar to what you get from a grocery shop for your fruit in a brown paper bag if you follow what I mean, then cut it into slivers and soak in diluted black acrylic paint and then hang out to dry.
heres a link I did on this technique-
http://www.shipsofscale.com/sosforums/viewtopic.php?f=77&t=1539
Hi Maarten,
I have given up using ebony timber, as its horrible to cut and sandpaper. I think I will paint the wales black for this model.
Hi Zoly,Hello Brian,try to use pear or boxwood and stain black the whale ,I think its much better than paint
