- Dec 1, 2016
but if i want to show off the interior of the cabin the there is more building to be done, let's take a look at the drawing there are more timbering between the last frame Z and the stern timbers
you can see the timbering on Hahn's model
having built a 3D model i can split the hull and take a look from the inside. What your seeing here is inside the cabin and the cabin floor that extends to the balcony.
looking from a view outside the cabin you see the rear wall of the cabin and the space between the wall and the balcony is a doorway so you can walk from the cabin through the gallery and out on the balcony.
a view of the back wall. notice the statue is defying gravity and just floating in the air. I have studied the structure of the stern timbers and have yet to come up with a solution to the floating statue. I did calculate the size and weight and if carved from Oak it would weigh in at a few hundred pounds. So it needs something strong and sturdy to stand on and not just a small molding.
