LE ROCHEFORT - Harbour yacht from 1787 1:36 by Tobias (Monograph by ANCRE)
I chose to make the window frame oversize for height and then beveled the top and bottom to fit the opening (by hand). My light divides were applied on top of a mica sheet to both the inner and outer faces (a sandwich approach) - to the extent it is noticeable, then, mine are perpendicular to the glass rather than parallel to the frame. For that aspect I like your method better.
But I'm not sure if there would have been wood divides on both the inside and outside faces in real life. I assumed so... but maybe not. I guess most everyone only applies the glass/mica/plastic on the inner face as you will be doing.
A kind of double glazing, the second time I deliberately decided not to use glass. The liquid glass that I used on Le Coureur turned milky white in places, either it reacted with the superglue or it had expired. So I resorted to the second product, but this turned out to be a bit rubbery and after a short time it looked unsightly. All the dust stuck and it couldn't be cleaned properly. I found a very interesting article in the French forum in which the "glass" was discussed, which at the time was made of very thin leather and treated with paraffin or something similar. It was rather light brownish and semi-transparent, so probably not real glass.
Thanks Peter for your feedback. Sorry AL-FI? I already know some abbreviations from my kids and I don't know these now, please be so kind and explain them to me. ROTF
We used that in the Bluenose area often: Artistic-License and Free-Interpretation. For all the option of parts that are not documented.
Hello everyone and have a great weekend.
The next phase begins: planking the starboard side. A very tedious process, as I've discovered, with a maximum of one row per day. Here, I decided to have the dark hornbeam planks follow the waterline. I can't yet say whether it was a good idea for my first hull planking ROTF . Here are the initial progress after three evenings this week.
Witaj
Dobry początek Tobiaszu, trzymam za ciebie kciuki jest to powolny proces ale dużo satysfakcji po ukończeniu. Pozdrawiam Mirek
Hello
Good start Tobiasz, I keep my fingers crossed for you, it is a slow process but a lot of satisfaction after completion. Best regards Mirek
Hi Tobias, no doubt you researched this step... but I don't think I have seen hull planking where each strake didn't run from stem to stern (well, I have seen plenty of examples of simplified model planking done that way but not on a 'real' ship and not on a model as given over to the details as yours). I'm sorry if I'm missing something but I wanted to ask about this before you get too far.
Hello Paul,
you're absolutely right that this type of plank doesn't exist. I'd like to follow Le Rochefort's color scheme, but since I'll never be able to paint it cleanly, I'm trying to create the actual black area with the wood I have available. Ricci used this method on his L'Amarante. To perhaps explain it better, I'm attaching a picture of LR to better understand what I mean.
Hello Paul,
Got it. Nigel did the same on his Soleil Royale. A very clever technique that will require some careful work (you are definitely the man for the job). Thank you for explaining - I was a bit timid about posting because you work at such a high level that it was all rather mystifying to me...
This is my first hull planking, and I hope I succeed. Otherwise, I'll have to dismantle it. It's completely new territory for me. The individual planks all have different dimensions, varying tapers, plus the curvature of the hull, the damping of the planks, etc. It will probably take a while, but I'm confident I can manage this part fairly well. Therefore, I'm grateful for any advice.
Good afternoon Tobias. A very unique way to plank by following the “painting” lines vs the hull planks. I think it will be very effective visually and a challenge no doubt. Enjoy. Cheers Grant
At the end it’s gonna look like a half-cut saw model on the waterline, Tobias.ROTF Above the waterline the dark hornbeam and below the ‘normal’ wood. The start looks promising with nice connections of the 2 different planks.
Hello Grant, it's going to be a tedious and exciting process. I've definitely learned one thing already: First, do the planking inside and out, then build out the interior. The further you get toward the keel, the more clamps you can get to it.
Hi Peter, if that doesn't work, I can saw it in half at this point, which would allow me to join your exclusive Half-Cut Saw Club. Interesting idea. ROTF
