You have really succeeded, very nice, Tobias.
That’s looking very nice, Tobias. Especially with a 'just on time' adjustment according to 'the plan'. The arc gives a beautiful contrasting accent.@pianoforte @Steef66 @Jimsky @GrantTyler thank you for your comments and interest. Also to everyone else who left a like.
Just a small update with an attempt to implement what is shown in the plans.
The muntons are angled?@RogerD Thank you, I'm glad if it inspires you.
Revision of the windows, here I have adjusted the lower part.
The windows also had to be replaced; unfortunately, they can no longer be opened; I would have to remove the upper beams to attach the hinges.
The left window still needs some adjustment, the bars are still too thick. The nameplate was only attached provisionally, I definitely need to change something here. About the name: Le Saint-Louis is one of 23 sister ships of Le Rochefort, which is Indian.
Paul and Mirek, unfortunately it is not clear from the plans, it is my own interpretation. I would like to add a small drawing. The blue frame would only rest on the corners and I did not like the look of that and it was not logical. That is why I decided on the red frame, whether this is correct or not I cannot say.Wygląda na to że Tobiasz robi okna pod kątem , tak to wygląda na zdjęciach Pawle. Tobiaszu fajnie wygląda twoja rufa. Pozdrawiam Mirek
It looks like Tobiasz is making windows at an angle, that's what it looks like in the photos, Paweł. Tobiasz, your stern looks great. Best regards, Mirek
The red one looks logical, Tobias. No problem with you AL-FI.Paul and Mirek, unfortunately it is not clear from the plans, it is my own interpretation. I would like to add a small drawing. The blue frame would only rest on the corners and I did not like the look of that and it was not logical. That is why I decided on the red frame, whether this is correct or not I cannot say.
I originally wanted to cut the rungs in half, but I didn't quite dare to do it because the wood is very brittle.
I chose to make the window frame oversize for height and then beveled the top and bottom to fit the opening (by hand). My light divides were applied on top of a mica sheet to both the inner and outer faces (a sandwich approach) - to the extent it is noticeable, then, mine are perpendicular to the glass rather than parallel to the frame. For that aspect I like your method better.Paul and Mirek, unfortunately it is not clear from the plans, it is my own interpretation. I would like to add a small drawing. The blue frame would only rest on the corners and I did not like the look of that and it was not logical. That is why I decided on the red frame, whether this is correct or not I cannot say.
