DE 7 PROVINCIËN (1665) 1:50
As a prelude to more difficult carving I replaced the ornament, which is used as inlay in the bow, because I found the earlier version too massive. And now was the right moment to correct that, before all the bow parts are joined together.
First of all a piece of wood was made to fit the housing; then the shape to be cut out was marked, holes drilled and the carving was made. I used both gouges, files, drills and my new nail drill.
View attachment 508949View attachment 508950View attachment 508951
View attachment 508958View attachment 508953
Another carver with improving skills in no time! That looks very nice, Herman.
Wow, you have it in your fingers. Excellent job Herman. I know the dificulty here. You need to carve both sides and be careful not to break your piece.
Thank you Stephan.
You take the words right out of my mouth.
The former carvings were more relief carvings, done flat on the table. This 3D carving work requires a more careful approach.
First of all you have to take care not to cut in your fingers and the ornament is too small to use protective gloves.
And second it is very fragile, you can hardly use force, otherwise it will break (learned it the hard way and started all over again).
Nice job!
I used to glue the wood with rubber glue on to a supporting piece of triplex. Then I cut out the carving, finished it as far as possible and dissolved the glue with paint thinner. At least it reduced the danger of breaking during carving.
But you apparently did not need any suggestions. :)
Thank you Ab.
Suggestions are always welcome. I learned most, if not all, from picking up all sorts of guidelines, tips and tricks and suggestions from our forums. And I will also need the necessary suggestions in the future when I am ready for a new chapter of the build. After all, most of what I do, I do for the first time so without suggestions I would certainly not get far.
Good afternoon Herman. Yep you totally owned this. Wonderful. Cheers Grant
Dear Herman
Wonderful carving work! I love it!
Hi Herman, Sorry to be late to offer my condolences on the loss of your Mother. I'm just getting caught up on your beautiful ship. All of your work is just top-notch! The most difficult, the carvings, are executed wonderfully and make me excited to see more.
You've seemed to have gained back your momentum.
