True storyI bet his cost goes up when he builds a nice display case to hold this beauty!
Good evening Jan. Thank you very much. It’s been a challenge with loads of fun. Cheers GrantImpressive, very Impressive, all on a $17 budget.
Jan
Hi Alex. This is a true story. I will send you a pic of my shipyard when I get home. It is a bit of a mess and no allocated space per model - I just play in a disorganised manner. Cheers GrantBeautiful rigging work Grant. This is where microsurgery skills, lean fingers and good eyes are needed...
I guess you are working on Bounty's rigging while you wait for extra sheets on your Enterprize. ?
BTW, do you have different work areas for different stages of your builds ? Send us a picture of your shop.
I find it always helps to have projects at different stages to keep interest.
Alex R
Me too, as you can see on my dedicated bench for Flying Cloud. I have seven worktables and benches (left over from my furniture days) all littered with crap!Hi Alex. This is a true story. I will send you a pic of my shipyard when I get home. It is a bit of a mess and no allocated space per model - I just play in a disorganised manner. Cheers Grant
A nice stay with a nice scratch build block, Grant. And you are a brave man with the lighter .....Good morning
Main stay and foremast shrouds.
The U blocks I had to make from scratch…..not the best I have seen. I have run out of left over kit natural rope so she is now getting some of the good stuff I have in my stock. It makes a big difference.
View attachment 507365View attachment 507366View attachment 507367View attachment 507368View attachment 507369
And burning off the fuzz….
Cheers Grant
It could end like the real thing. We wait for it.Burning off the fuzz in situ!?!?!!?!? COOL!
Thanks Peter. The fireworks look worse than they actually are. I flick the lighter so there is not a consistent flame. It really works very well if you are using cheap rope.A nice stay with a nice scratch build block, Grant. And you are a brave man with the lighter .....
Good Afternoon Roger. Thank you for the compliment. I am very happy with the restoration considering the challenge associated with it. As for the blow torchGood morning Grant, I went back to your first post (initial page) this morning and man what a remarkable difference you have made from then till now. The Bounty “face lift” is a great achievement.
You have guts using that giant blow torch at such close range for the fuzz. Visions of Grant’s Fireship - yikes.
It is more “bark than bite”…luckily.Thank you Daniel. The British used the U blocks on some of the ships of the line- the Victory had this configuration. The Bounty and smaller ships used 2 “heart blocks” like so :Those U-blocks are really interesting, unique haven't seen any quite like that before. You have an awesome restoration going on!
Good afternoon Gentlemen. The picture makes it look worse than it is. I flick the flame over and over onto the fuzz. It really works well with the cheap fuzzy thread. I have only had one accident and burned a rope off. It was in the early days when I was still learning how to play with fireOH BOY, the fire department would just be leaving after having saved the basement if I tried that fuzz burning trick.
Jan
. Cheers GrantGood evening Peter. Thank you very much indeed. Your encouragement is much appreciated. Cheers GrantYou are playing with a great re-build Grant , a big WOW is in place, and i take of my cap for you.
Recognicable Grant, happens to me also. (repeatedly)Good evening Peter. Thank you very much indeed. Your encouragement is much appreciated. Cheers Grant
PS. apologies for the late reply Peter, this message has been sitting in my "draft" for a while as I did not "post reply".![]()
) has had a little dabbling now and then.
. it will come good.
