The Mighty Panokseon (Plank Board Ship)
This is going to get wordy, and for that I apologize, but it's been a saga this week with some ups and downs.
The planking for the lower deck is finally done. Or at least as done enough. It's not perfect by any means, but as previously stated, at absolute most, only about 10% of this will even be remotely visable on the final product once the rest of the superstructure is compete; primary only the areas close to the doorways. I havbe decided to make this a semi-full interior, with the officers quarters, railings and stairways to the other decks, anchor, and the two officers cabins at the stern. The unifished squares I left for the interior support beams to fit in.
While I was letting this dry outside after applying the stain, my upstairs neighbor decided (for some reason) to dump water off her balcony, soaking the deck. My wife, bless her heart, noticed and brought it back inside soon after. I had to stack a few reams of printer paper on it for a while to work out the warp that was starting to form.
Following this, I returned to the hull to start preparing the hole for the rudder shaft. Initially, I was planning to have the shaft be exterior, as the hisorical painting of the ship, and several modern reproductings, depict it this way.
Now, this might be a but presumptious of me, but it began to strike me that this set up is historically inaccurate. Firstly, many paintings of the panokseon show that it's two masts could be lowered, presumably during battle and storms. In all that show us such, the masts are lowered toward the stern, where the rudder tiller would be, which doesn't make a very much sense. Furthmore, in another painting from the 17th or 18th centry, that is a bit better quality to the former, no tiller is present on the upper deck. In the painting below, the forward mast remains up, while the aft mast is lowered onto a support where the tiller would (supposedly) be located.
Another reason why I think it would be implausible for the rudder shaft to run along the exterior, with its tiller on the top deck is because it completely contradicts the entire intent behind the design of the panokseon. On early fighting ships of the Joseon navy (including the panokseon's most immediate predecessor), the fighting and rowing would all occur on the same deck. The panokseon was designed not only to give the fighters a more elevated platform to fire on the enemy from, not only to make the ship harder to board, but also to keep the oarsmen protected on the enclosed lower deck. To have the helmsmen, someone who is so vital to the ship, located on the fighting deck, or even the rudder shaft exposed on the exterior, contradicts this intent to keep those responsible for the ships movement and operation safe and out of the way. So I must assume that the rudder shaft ran through the interior, with its tiller on the middle deck with the oarsmen.
So, with this in mind, it was time to bust out my drill. This part was slighly nerve racking as, if I got the angle wrong, it could screw up the stern to such an extent that I have to scrap the entire hull! Luckily, it didn't go so bad, and the exterior hole did come out almost exactly center. But the entry hole on top must have been slightly off (the drill bit probably shifted while I was trying to get it started), so the shaft is not perfectly verticle. It emerges the exterior going fairly noticibly to the starboard. There might be a way to fix this, so I'll leave it alone for now until something comes to me. If anyone has some ideas, I'm all ears.
And then there's the next battle; the heavy horizontal timbers that the verticle supports will sit on. Because of the fairly extreme curve at the bow, I need to apply some extreme bending as close to the shape as I can as I don't want the wood to be constantly stressed by focing it into place and just locking it in with glue. For the timbers, I'm using two pieces of basswood, about 4 cm x 4 cm. I don't have the appropriate apparatus to steam these properly, so I've had to resort to having them soak in boiling water and then bending them. I've even applied a hot iron while they were being bent to help the wood form, but the results were...modest is probably the most generous term.
Again, if anyone has some tips on best practice here, I'm all ears. Otherwise, I'll just try to continue to soak, bend, and iron multiple times over the next few days and home it gets a little closer each time.
A much shorter update this time: I found a way to bend the squared dowels. I just had to make a jig that could hold the shape in place and let it dry over night. (Just declare me Captain Obvious of the USS Amateur, I suppose.)
I still have to work more on the shape to get the whole thing to actually rest along the deck, maybe requiring a larger jig, but the process at least does work, so the other 3 should go more smoothly.
Apologies for the delayed update, but I'm finally done! The finished panokseon in all her glory!
Well, okay, this is my daughters version of it. I felt bad that I couldn't let her help me on mine, so I showed her how she can make her own (maybe we'll start with wood and power tools once she's in 3rd grade.)
Now onto the real thing. The small jig worked, but I ultimately needed something bigger, so I grabbed a left over piece of wood from a shelving project, cut it up with some small dowels, and a few drill holes later, I had a jig all ready to get some wood bent into shape.
With that, both strips just needed to get their first coat of dark oak stain and then some wood glue with gentle, consistent pressure.IMG_6116.jpg
There may be a few gaps, but nothing I can't fix with a bit of wood filler later on, and they're all in sections that will be nearly impossible to see anyway. Now it was the next few steps that gave me the most anxiety: subtractive process. Significant mistakes here can really set me back and this was why I was so delayed on the updates. I needed to work up the nerve to move forward. First, I needed to shave little notches on the underside of the parallel beams so the perpendicular support beams could rest inside them.
This proved to be easier than I thought, just requiring good technique with the hobby knife and a file that was exactly the correct width, then they were all set for the support beams.
img_6121-jpg.506281
Really, much of this work won't even be visable, but I'll feel good knowing they're there. Now, I need to go back to the hull and begin to get it ready to be fixed to the deck. This will require more subtractive process, which again, is making me nervous.IMG_6126.jpg
Similar to the support beams, I'll need to cut notches out of the gunwhales so that the horizontal beams rest nicley in them. I already know how I'll do this, I'l just have to measure once, measure twice, and then a 3rd time before I do any cutting. I'd hate to have to redo the upper planks if I screw this up! Wish me luck.
So I have gotten the notches carved out of the gunwales, so the deck will sit relatively flush on it. (They kind of look like castle crenellations) Unfortunately, I did get a little overzealous with some areas, but it'll try to patch it up with stainable woodfiller once I get everything fully glued down. I'm just dry fitting at this point.IMG_6133.jpgIMG_6134.jpg
On a more positive note, I made some more progress with the ruddershaft feedthrough. I might try to adjust it further, but it's a lot more vertically strait than it was before.
For the next step about the hull, I'm kind of of in a bit of a debate with myself, so I might post a poll on it later on for additional feedback.
I was a stuck in a bit of a rut and neglected to post any real updates. If you would have told me a month ago that the staining process would give me the most grief, I would have tied you to a mast and sent yout out to see on a stormy day. But it turns out that basswood, which my ship is mostly constructed out of, doesn't like to stain very evenly. But alas, as of 2 weeks ago, I finally caught back up to where I was at in my original ships construction.
IMG_6169.jpg For comparison, I placed it next to my original construction. Nothing makes you feel better about your current screw ups than to be able to look back at your first-time round screw ups. But as you can see, the stain job is a bit splotchy. I spent the last few weeks looking into how to smooth that out a bit. For posterity, I should share another mistake I had to take care of. When removing material from the upperbow section to make room for the framing timber, I did not take into account the width of my saw blade! Frickin' amature hour over here!
You can see right under the framing timber where I had to fill in the section with some stainable wood-filler. I've actually done a better job at shaping it up and color matching it, but still, it's noticable if you look for it. For any fellow newbies on here, say it with me this time: always take in account the width of your saw blade.
So that's where I was at about 2 weeks ago. Since then, I had to step away from it for a bit to figure out how to tackle current problems and next steps. But I'm getting back to it now, so I'll have some updates again pretty soon.
Looks fine to me. For future reference, a coat of sanding sealer might help prior to staining. Always try something new on a test piece before you try it on your project
Thanks for the suggestion. I hadn't actually heard of sanding sealer before, I'll look into it.
Well, it's been nearly two months and I'm sure all of you (all five) probably thought this project was dead. Luckily, the project is a alive and I just got buried in work (late April through May is my busy season). But if I'm being honest, I was also a bit stumped on the next step. With the hull mostly done, it was time to move onto the superstructure. While I had an idea the design, the actual execution gave me trouble. But rather than bore anyone with that story, I'll get to it.
The overall structure is relatively simple, with verticle timbers going around the sides with horizontal (I presume) planks running between them. Below was a rough mock up of the idea to see if it would work. Luckily, it did, but it would mean a lot of tedious prep work, originally by hand (damn, I'm envious of those of you with laser wood cutters).
To complete the exterior of the lower deck, I would 36 timbers all of fairly equal length and about 120 planks. In the grand scheme of things, not difficult. But, to actually make sure the planks all line up and to have them held in place with a mechanical fit rather than glue alone, I would need to cut grooves into each timber.
While a rough version of this for a mock up was fine, creating final versions of all this with only hand tools was a bigger pain than I was prepared for. I discovered, sadly, that I just was not skilled enough to cut through these pieces at perfect, 90 degree angles, at least not every time. After messing up about 8 pieces, I finally called defeat and decided to pony up for some electrical assistance.
While I hated to break my self-imposed rule of using basic tools almost as much as spending even more money on what I promised my wife would be a simple, inexpensive, and quiet hobby (I'm sorry dear, I really did mean those words at the time), this thing saved me so much time and effort. Although not all the pieces are exactly the same length, they're all close enough where I could fix them with either some light cutting or sanding. And if not, I made spares.IMG_6250.jpg
Funny enough, the grooves were a bit simpler to do. I just had to dig through my tools to find a saw with the right width and then whip up yet another jig. Granted, I went through about 3 different versions, (the photo above includes version 3 and the ruins of version 2) but I eventually got there. It essentially is two stips of wood glued down to hold the timber in place, with additional pieces covering the top, save for a gap which would guide the blade through. Following that, each groove just needed some light file work to smooth it out and widen them a bit.
These timbers also had to come in three flavors: H-beam (20), corner beam (4), and u beam (for doors) (12)
That's about where I am at today. Luckily, I'll have a lot more free time now where I can just sit of focus on my progress. The plan is that I can start gluing the beams into place over the next few days and start preparing the planks by next week. Updates should be coming more regularly again. My next big headache will be how to create working hinges at a 1:100 scale. Yay!
"Perfection is the goal, but never the finish line." My new matra as I continued this stage of the build. There are some errors for sure, some which I can correct, others not, but if I chase perfection, the ship will never be complete. Overall, I'm happy with how it's looking.
The planking on the lower superstructure is nearly done. I plan to place functioning doors in the few open spots, as soon as I figure out how to make the hinges. Although I'm sure I'll figure something out, any resources on 1:100 scale hinges would be welcomed and appreciated.
I forgot to mention, the next update won’t be for about another two weeks as I’m in Hawaii for the next seven days.
I’ll be sure to visit the Missouri and Arizona while I’m here.
Don’t forget the Bowfin.
Unfortunately, the Missouri is not being well maintained, and there is much less of the interior of the ship accessible to the public than many of the other battlewagon museums.
Alright! I got back from Hawaii a few days ago, and not a moment too soon! (Seriously, glad everyone there was okay).
I actually ended up skipping the Missouri for the Bowfin. The museum was more interesting, the submarine was awesome, and I had already been to the USS Iowa several times with my daughter, so I didn't feel the overwhelming need to drop another bill to see the same class of ship. I did get some good photos of it on the way to the Arizona, though.
Anyway, with the trip done, I wanted to hit the ground running before I got back to work on Friday. I finished planking the ships stern and began work on the interior. Although not pictured, I spent 2 hours of careful, midnumbing sanding to get the top completely flat and even so the next level can sit perfectly above it.
On the mid deck, it is believed there were two cabins at the stern, one for the ship commander (captain), and the other for the officers (there would be 1-3, depending). I remember seeing these when going on board one years ago, but sadly I had no pictures, so I had to scour the internet a bit. The best I could find was that (somewhat) showing them inside a geobukseon, which was fairly similar in its design.
Not my picture, but I think this may be the same Geobukseon I visited myself as the source cited it as the one in Tongyeong.
Anyway, the few pictures I found show them with double doors, but due to the incatracy of lattice doors, at 1/100 scale mind you, I'll be going with single doors for each room. This is what I managed to whip up today.
I made these with layers of balsa wood sheets, 1/32' thick, with the "rice paper" backing made with tissue paper. They look somewhat sloppy up close, but these are interior details that I don't think will even be very visable in the end product. I do think the ring pulls came out very well, though. After searching and failing to find ones already made online, I opted to make them from stratch using (I think) an 18 gauge brass tube I cut into rings and 22 gauge brass wire.
I'm just dry fitting them for now. Once I figure out how to fabricate some (relatively) scaled hinges, I'll blacken them chemically and then fix them on. Hopefully, I'll have more updates by next week, if not this weekend. Cheers!
I didn't quite make make my goal for the week, but dang it all, I came close!
For starters, I finished up the two interior rooms on the mid deck. Again, going off reference photos from the interior of the Geobukseon, they appear to have "salmun" (wooden grid with paper backing) windows, so I decided to add some to mine as well. They were actually a bigger pain in the butt than the doors!
The reference photo depicting the rooms at the stern with the windows.
Then it was time to wrap up work on getting those doors functioning. As the smallest hinges I could find online are 5mm x 10 mm (which is would cover about 25% of the entire door, I had to try to fabricate some myself. Ugh! So I took some thin brass sheet, cut out some small brass slivers, busted out the needlenose pliers, and got to work.
They may not be uniform or very pretty to look at, but that's the best I can do when working with pieces that are about 3 mm long and 1 mm thick! If I go this route for all other doors on the ship, I'll need to make at least 52 more of these loops. (I am all ears for any other ideas!) With that, it was time to bring out some good ole' blackening solution and get them mounted on the doors.
The hinges do still look huge for the scale, but meh! It was my ambition to get these doors mounted on the frames and functioning before the end of today, but it I just did not have the patience and steady hands needed for the task today. Next time, the doors should be mounted and I'll either get to work on either the oars or the anchor next.
So the door hinges are giving more more trouble than I like. I can get them functioning, but it looks very sloppy. I looked around, and I did find a thread on how to fabricate hinges, so I may try that method soon. Unfortunately, I got one of the doors semi-installed before things started to go south, so if I can fix it, I may just have to glue it closed.
Right now it's just dry fitted.
To stop myself from getting burned out on the doors, I decided to take a detour to the stern exterior. Most modern repoductions show an exterior lower deck at the stern. I'm still not entirely sure what this section was for, but they are consistently featured on just about all reproductions of ships from the Joseon era.
I also decided to redo the tail fins slightly, as I was unsatisfied with their shape.
