Quite a difference in lenght of the hull John if you see them next to each other.
Regarding repositioning the top wales and frieses it gives the model a much better appearence.
Thank you Maarten, hopefully mine will look as good as yours, I won't be double planking the hull like you did, just painting it off white, and I'm going to leave the carvings as Box Wood with the clear Beeswax finish, thanks for all your help with the info and the help of your build logs,
Best regards John,
, yes , I dog the heels of the RC builders..saved me a lot of headaches!!
