Well, now you have two great builds to work on. Good luck mate.Happy day for me, just got home and my long awaited delivery of the USS California has arrived. I did a side by side comparison of the docking keels and think the ones I scratch built on Arizona is fairly accurate. The thickness is 2.5 mm.
Which Dremel accessory/tip did you use? Mini sanding disk?Steve, I used a Dremel to grind away the plastic, then sandpaper and Tamiya modelling putty.
Interesting. Haven't seen those before. Will take a look at what's available.Steve, I purchased something like the picture below on Ebay. Its a flexible rubber sanding attachment. I use it with the 90 degree Dremel tool attachment.
On the 'dots', they exist on pretty much all the wooden deck kits. I found some research ( and a photo which I'm trying to find) that indicates they were actually lights in the deck. I believe by 1941 they had been removed.i hate to be the bearer of bad news but those rows of dots on the main & upper decks are not supposed to be there. it appears the deck manufacturer used gaming files off world of warships or similar as some 3d printing companies use the same files to print their 3d warships. look at these pictures that i had circled those dots. look at Arizona's Booklet of General Plans 1941 Sheet 7 - Upper Deck & Sheet 8 - Main Deck as you will not see those dots.
Funnel looks fine! Look forward to seeing the items broken out!Hi guys,
my 3D printed upgrade set arrived today. I am impressed with the fine detail of the parts. They are a work of art. I will post more on these soon.
View attachment 517846View attachment 517847View attachment 517848
My photography does not do the fittings justice Steve. They are exquisite.Funnel looks fine! Look forward to seeing the items broken out!
Have fun clipping all the supports out, without clipping actual piping or structure! The details look great, I need to learn to use my printer better for this kind of details.Hi guys,
