Thank you very much. A few more steps and you can glue it and then the base will be even stronger)) I can't wait to fix the frames, but for this I still need to make a frame.A very nice explanation and outcome, Sergey. A solid base!
Thank you! I just didn't breathe at that moment))))Very skillful carving of the numbers, Sergey!
Nicely made details and explanations, Sergey.2.5 Rework (grooves, holes and XVIII)
As I showed above, the BL6 detail needs to be finalized, but... the method that, according to the instructions, is a little more complicated than what I did. Plus, in my method, I was able to eliminate the hole that appeared due to an error in the size of the parts.
I cut some of that detail along the line of the bottom skin board...
... and the result is a slightly larger hole ))) ...
And then I glued a piece of wood to the false keel...
... and after fitting...
... it turned out like this.
The next refinement was the holes for the deadeye stay. Since I was redoing the part, I decided to do the holes correctly. And again a little theory.
In short: the holes should not be exactly in the center of the part, since there is a metal bowsprit holder. And also the holes should not be one after another, since the ropes will then go along the same line and overlap, wedge and grind each other. Therefore, they must go radially at approximately the same distance.
Plus the holes are too big.
On the sampler, I made not only holes and covered with oil, but also made decorative lines.
It is better to make holes starting from a small diameter and raise. Controlling the parallelism and accuracy of the exit from the other side.
I made stripes with a knife.
The top thin line is simply a cut with scalpel (s). The lower one is more complicated. You need to make two cuts (a, b), and then carefully remove the tree between them (c) and you get a larger cut (d).
Well, here's the result:
The third revision was the Latin figures of the ship's draft.
On small ships, these numbers were on the front of the ship on both sides and went parallel to the waterline along the arc of the skin.
To do this, I made a small stencil, calculated the distance between the numbers and drew parallels on which the numbers will be applied. And with the help of a ruler for cutting, he drew an arc. And applied numbers.
Then he cut out their silhouette very carefully with a knife. I recommend cutting each line twice. Above and then below and, as it were, bringing them together. Thus, there will be no risk of drawing a line further than it should be and the section will be of the same thickness.
I used tape to transfer the position to the other side. When peeling it off, it leaves all the markings on itself and then you just need to lean the tape (not with the adhesive side) and put dots on the sides of the lines. And then just draw those lines between points. And since the tape is positioned in the same way as on the other side, the entire markup will be mirrored (the main number cannot be made mirrored))
Then you need to erase the pencil and you're done...
Of the improvements, it remains only to adjust the landing meta for metal parts and you can glue both keels.
Thank you very much. Yes, I try to think everything through as much as possible in advance. It takes a lot of time and it is not always possible to think everything through, but if you do everything as timely as possible and take into account future manipulations, then this will simplify future steps or even make them possible, since sometimes if something is not done on time, then it is not always possible to fix it. Now I am just thinking about one global change and deciding whether to do it... but this is a little later)))Good morning Sergey. Wow. After reading your work on your keel, grinding line etc there is much I missed out on. There are one or two things I can improve on when I take it out the cradle so thanks for sharing your detail. You have skills for sure. Cheers Grant
Thanks a lot.Nicely made details and explanations, Sergey.
Great achivement!2.6 Lodgements for front and rear frames.
Finally, the final part of this chapter... several parts and you can collect everything in one lump.
As I mentioned earlier, I will redo the rear lodgements, since those from the set are light.
The plus is that although there are not many on the dies, there is an empty space where you can place the parts. Cut out with a hand jigsaw and refined with files.
The photo is not very visible, but in life the old ones are much lighter and grainy and I do not regret the time spent on processing new ones.
I did the processing with a grinder, but I'll warn you right away... for beginners, I recommend that you definitely practice on the probe, since the manipulation is quite difficult.
It is imperative to set reference lines to see the edges of the parts. Well, here is the result before and after grinding.
Well, it is not unimportant, symmetry and repeatability, since the sides are mirrored and the parts should be the same.
Naturally, the parts are pre-processed and after fixation, they will be ground in place together with the frames. But now I will not fix them. During the assembly process, I will once again adjust everything to each other and adjustments can be made.
I also prepared the details of the BL30.
Cut off the holders and sanded it, but again, I did not contour it like 3 pairs of front frames. There are special stickers for all these parts, but! I do not recommend blindly believing in the accuracy of all these stickers. It is better to do all these manipulations in place during the assembly process so as not to polish too much.
And the last detail was a temporary keel. Its purpose is to replace the real keel at the time of assembly of the case. And after the final grinding of the case (and most likely during the grinding process), it will be removed and the case will be scanned. All this will be necessary so that the hull bulb for the second model is without a keel. And the keel will be made and glued at the time of lining with slats. On this body from the set, a real keel will be installed after the external surfaces of the model are scanned and finally polished. If nothing is clear, then in the future I will talk about it in detail.
The temporary keel was made from fragments of templates (jig) on which there were frames. I glued suitable pieces together with diagonal joints and two layers with just a little grinding gave exactly the same thickness as the keel. In the next chapter, I will show in detail and tell you about this detail...
... in the meantime, we can officially say that chapter 2 is over!
P.S. and finally it will be possible to show the slipway, which is already ready for me and is waiting for publication.
Thank you. Yes, the frame is a good thing, but there are still many inconsistencies, unfortunately. Often you have to adjust 100500 times. Now I'm making the front part, and it's really difficult there. And I had to redo several parts. But it's still fun and brings pleasure))) And what else do you need from a hobby?Nicely done, Sergey! It is quite difficult to get everything properly in place on the stern. The jig seems very helpful!
Great work Sergey. You should copyright this log and sell it a an instruction manual….Under the stern, I finished, now you can prepare the details of the stern itself.
To begin with, you need to glue parts 37 in pairs, having prepared the surface as much as possible and squeezed as much as possible so that the glue seam is practically invisible, since logically it should be as one part.
And while they stick together I prepared two other details. One slightly more complex shape. But according to special stickers, it is not difficult to make a uniform as before.
But you need to be careful with the corners, since the cherry tree is very fragile in fiber and you need to avoid chips. And here's the first fitting.
But with details 37 it turned out not so simple. And the difficulty is not in the implementation itself, but in the fact that the stickers in the set are not grouped correctly! I signed A and B so that it was clear from where which stickers and I would give detailed instructions on how to process these details.
So, I processed them on a grinder and refined them with sandpaper with a cylindrical base.
The most important thing is that you do not need to stick all 4 stickers at the same time. First you need to stick the top and bottom. Grind all unnecessary and only then stick two side and already grind other planes on them.
After that, you need to fit these parts as much as possible with the other two. So that the connection points are without gaps and steps.
But the most difficult thing was to fit it without gaps.
And the problem is not skills... these parts initially formed cracks, that is, they were small. But I came up with an implementation to eliminate all these gaps. Further in the review, I will tell you in detail about this.
To properly fit some parts, you sometimes have to adjust the slipway.
And after the final checks, I glued the side pieces (37) and the back, but I didn't glue the front piece.
The frame was strong and it was possible to pull the keel out of the slipway again.
And in order to make it easier to get the model from the slipway in the future, I once again adjusted the details of the slipway.
That's all for now, tomorrow there will be the 3rd part of the work on the stern. Good weekend everyone!
. Seriously tho it will be an amazing help to future Alert builders. Your wood work is so clean as well.True story I have found this out the hard way alreadyBut you need to be careful with the corners, since the cherry tree is very fragile in fiber and you need to avoid chips.
