HMS Enterprise 1774 POF 1:48.
Good afternoon all. Just a small update on the stern timbers. I fixed the broken counters and fitted the side counters Tom sent me. Took a long time to get these ready, plenty of sanding and cleaning up required.
Close up of the fitting. The joins came together pretty good although I did miss the measurement of the deck clamp by 0.5mm. Still looks good tho.
From the rear and outside:
And the side timbers added:
Cheers Grant
Nice step on this complicated aft part, Grant.
Nice job Grant, those two large counters (odd name to me) appear complicated in their shape and even more complicated to place correctly.
Good morning Daniel. They are pretty complex( Kudo to those guys who scratch make them) and meet 3 different parts all at differing angles. I got them pretty close…..hopefully this remains true when I take her out the jig.
Goodwin refers to these as side counter timbers , Sutherland as stern timbers and I have seen them called fashion pieces. To me they are those twisty thingings at the back on the side….ROTF.
wonderful work !!!
Great skill, loads of angles to consider. Neat as you like! Fantastic!
Certainly does Grant, terrific job.
wonderful work, Grant
Hey Grant,
that looks excellent once again Grant. That's great craftsmanship. I'll be happy to see any progress you make. I think I can learn a lot from you here.
Cheers Günther Ship-1
Good morning Gentlemen. Thank you very much indeed. Your support and encouragement always makes a big difference…..especially when I feel a little out of my depth so to speak. Cheers Grant
Cheers Grant
Beautiful work Grant
Good afternoon.It was a cold, wet and blustery day today so I bunked going to the office. My desire to make more carlings, beams, ledges and knees was null and void. Ricochet Rabbit decided to come out and play.
The kit partners and chocks for the masts are sad so I scratch made a resemblance of these. I did not notch the fore/aft partners to accept the chocks as these where already fitted. (I had a feeling I would cock this up).
Here is my attempt cut from some left over cherry.
Foremast:
Cheers Grant
PS. Not yet sanded. I’m trying to be more accurate in my cutting and be less dependent on sanding…..hmmmmmROTF.
While I wait for the new parts I am going to deviate to deck beams and carlings etc.
Firstly I need to poly the internal frames below the clamp line. I was very happy, indeed, how the Cherry came out. It looks way better in real life and try as I may I couldn’t share this with you guys:
Some pics:
View attachment 516330View attachment 516332View attachment 516331View attachment 516333
Very chuffed and then ……
I knew this was going to happen just not while it is still in the cradle ROTF ROTF ROTF
Cheers Grant
Very pretty, Grant! Except for that last part. ROTF
Foremast:
Cheers Grant
Grant, you could also put the camera even closer so we can really see any flaw in your craftsmanshipROTF My bet is that all of the angles look perfect when your eye isn't pressed against the deck. Lovely.
Blessings.
Chuck
Blessings.
Chuck
or you can put the camera so close that everything is blurry and we can't see any of your flaws.... ROTF
You are doing a great job !
Good morning Gentlemen. If you do close ups you only see a few flaws vs a whole multitude…… ROTF Thanks for checking in on my ship guys- I do appreciate it. Cheers Grant
Good evening. WIP : Some more scratch building. The partner and chocks for main mast and the inner ducks for a chain pump. The kit does not include all these yet from my research a frigate has this. I included some lead lining for the ducts……all WIP.
and then a deep uncontrollable urge of unimaginable force ……the jig had to go..,
IMG_5653.jpegIMG_5642.jpegIMG_5644.jpegIMG_5650.jpegIMG_5648.jpegIMG_5651.jpegIMG_5646.jpeg
Cheers Grant
