Nice job Grant, those two large counters (odd name to me) appear complicated in their shape and even more complicated to place correctly.
**VIEW THREAD HERE** |
……. Still looks good tho.
Cheers Grant
Nice step on this complicated aft part, Grant.Good afternoon all. Just a small update on the stern timbers. I fixed the broken counters and fitted the side counters Tom sent me. Took a long time to get these ready, plenty of sanding and cleaning up required.
Close up of the fitting. The joins came together pretty good although I did miss the measurement of the deck clamp by 0.5mm. Still looks good tho.
From the rear and outside:
And the side timbers added:
Cheers Grant
Thank you Paul. Took a while but came out reasonably ok. I can work with this going foTricky part of the build, Grant. Well done!
Thank you kindly KeithSplendid workmanship my friend. Very well done
Good morning Daniel. They are pretty complex( Kudo to those guys who scratch make them) and meet 3 different parts all at differing angles. I got them pretty close…..hopefully this remains true when I take her out the jig.Nice job Grant, those two large counters (odd name to me) appear complicated in their shape and even more complicated to place correctly.
wonderful work !!!
Great skill, loads of angles to consider. Neat as you like! Fantastic!
Certainly does Grant, terrific job.
wonderful work, Grant
Good morning Gentlemen. Thank you very much indeed. Your support and encouragement always makes a big difference…..especially when I feel a little out of my depth so to speak. Cheers GrantHey Grant,
that looks excellent once again Grant. That's great craftsmanship. I'll be happy to see any progress you make. I think I can learn a lot from you here.
Cheers Günther![]()
Beautiful work GrantGood afternoon all. Just a small update on the stern timbers. I fixed the broken counters and fitted the side counters Tom sent me. Took a long time to get these ready, plenty of sanding and cleaning up required.
Cheers Grant
Thats the best description yet!To me they are those twisty thingings at the back on the side…..
Thank you kindly Gilbert.Beautiful work Grant
Very pretty, Grant! Except for that last part.Good morning Gentlemen
While I wait for the new parts I am going to deviate to deck beams and carlings etc.
Firstly I need to poly the internal frames below the clamp line. I was very happy, indeed, how the Cherry came out. It looks way better in real life and try as I may I couldn’t share this with you guys:
Some pics:
View attachment 516330View attachment 516332View attachment 516331View attachment 516333
Very chuffed and then ……
I knew this was going to happen just not while it is still in the cradle![]()
Cheers Grant
Grant, you could also put the camera even closer so we can really see any flaw in your craftsmanshipGood afternoon.It was a cold, wet and blustery day today so I bunked going to the office. My desire to make more carlings, beams, ledges and knees was null and void. Ricochet Rabbit decided to come out and play.
The kit partners and chocks for the masts are sad so I scratch made a resemblance of these. I did not notch the fore/aft partners to accept the chocks as these where already fitted. (I had a feeling I would cock this up).
Here is my attempt cut from some left over cherry.
Foremast:
Cheers Grant
PS. Not yet sanded. I’m trying to be more accurate in my cutting and be less dependent on sanding…..hmmmmm.
Grant, you could also put the camera even closer so we can really see any flaw in your craftsmanshipMy bet is that all of the angles look perfect when your eye isn't pressed against the deck. Lovely.
Blessings.
Chuck
Good morning Gentlemen. If you do close ups you only see a few flaws vs a whole multitude……or you can put the camera so close that everything is blurry and we can't see any of your flaws....
You are doing a great job !
... True story! It's a wooden kit, not a bacterial colony. To me, those mast partners are nicely executed. Good job, Grant!or you can put the camera so close that everything is blurry and we can't see any of your flaws....
Thank you Albert.... True story! It's a wooden kit, not a bacterial colony. To me, those mast partners are nicely executed. Good job, Grant!
