- Oct 23, 2018
Another friendly looking lion. I simply love it.
**VIEW THREAD HERE** |
You certainly have great carving skills, Herman. From what I see from you first sketches till this result is a great transformation of a piece of wood to a very impressive Lion.FIGUREHEAD - part 4 (final)
Here are the final pictures I took while holding the bow sections together with the figurehead wedged in between.
I enjoyed myself carving and there are a lot more carvings to be made, amongst others 2 more lions on the tafferel.
DittoWOW! What a beautiful carving! I wish I could carve like that!!![]()
Thank you Kurt.WOW! What a beautiful carving! I wish I could carve like that!!![]()
Thank you Grant. Now looking forward with more confidence to further carvings.Good morning Herman. What they all say…..WOW. Cheers Grant
Thank you Christian.Another friendly looking lion. I simply love it.
Dziękuję Mirek za miłe słowa.Witaj
Piękna rzeźba podziwiam . Pozdrawiam Mirek
Thank you Peter.You certainly have great carving skills, Herman. From what I see from you first sketches till this result is a great transformation of a piece of wood to a very impressive Lion.
Thanks Maarten.Wonderfull work Herman.
Hope you joun in Amsterdam after the summer to have a look at your build in reality.
Thank you Ken, for your very kind words.Hi Herman, I see you've made great progress. I have to say, your work has no problem passing the macro photo test!! Wonderful work. Your lion figurehead is a work of art. Just wonderful!!
Well Roger, I surely am. Thank you for visiting my build log and your kind words.Not being knowledgeable about Lion Psychology or any Psychology for that matter I can’t tell if he’s happy or angry. On the other hand, YOU should be very happy to have carved this fine Lion.
Well done!
Roger
That’s looking very nice,Herman. Steady on!NAILING - a matter of perseverance
Hi to you all. First of all I want to express my gratitude for all of your visits and likes, much appreciated.
I have started nailing the hull. First of all i have drawn vertical lines on the hull as representation of the frames. That completed i used an awl to pinpoint where the nails would come.
I then drilled the holes and started inserting my earlier fabricated nails.
The holes drilled are just wide enough to press the nails in. One thing is certain, they will not fall out.
I have now completed about 2/3 of the port side -under the wales only- and am not certain I have fabricated enough nails (about 9000). Some were used to experiment, some are rejected or break pressing them into the hull and my estimate was probably off. The joints also require more nails. So I might have to produce more nails.
As you might have noticed in the pictures the pear wood has shrunk a bit due to drought. It has been very dry here the last few weeks and my shipyard is directly under the roof which makes it quite warm. To increase the humidity a bit there are now some water tanks and every evening I hang a soaking wet t-shirt over my chair. Let's see how far that will suffice.
