VOC ship The Prins Willem (scale 1:75) Year 1651
my dear friend Stephan
Happy Birthday Birthday-Cake
I wish you all the bests and a very Happy day with your family
Good morning Stephan.
I wish you all the bests and a very Happy Birthday Birthday-Cake.
Enjoy this day to the fullest.
Gefeliciteerd met je verjaardag, Stephan
Also from my side a Happy Birthday, Stephan. Enjoy this day!
My best wishes for a very happy birthday Stephan.
Van harte, Stephan!
Wonderful! I hope you have a great day celebrating, my friend!
A very happy birthday Stephan!!!Birthday-CakeBeerBottleExplosion. Cheers Grant
Happy birthday!
A very Happy Birthday Steef.
I want to thank you all for the warm birthday celebrations. They certainly make the day. 59 years is still young they say.
Hi Stephan,
Happy birthday and up to the next 25.
Thanks Maarten, normally they say this at 25, 50 or 75. :DBut on to the 84 is also fine.
Hvad? Endnu et år allerede? Wow!
I det tempo kan jeg slet ikke forestille mig, hvor klog du bliver i næste uge – for slet ikke at tale om næste år! :D
Tillykke med fødselsdagen, min ven! Birthday-Cake
Må din dag være fyldt med glæde, latter og lige den rette mængde kage-inspireret eftertænksomhed.
Thanks Jim, no idea what all you are saying. But given the cake, I do appreciate it. Ps; I am Dutch. ROTF
Oh no... being multilingual is not easy.... ;) Here is the correct one (I think)
Wat? Alweer een jaar erbij? Wow!
Als je in dit tempo doorgaat, durf ik niet eens te bedenken hoe wijs je volgende week al zult zijn – laat staan volgend jaar! :)
Gefeliciteerd met je verjaardag, mijn vriend! Birthday-Cake
Moge je dag gevuld zijn met vreugde, gelach, en precies de juiste hoeveelheid door taart geïnspireerde reflectie.
Thought you still were 25. 8-)
After building a lot of rope walks and refurbishing a Creality Ender 3V2 printer I'm still working on my sails. My first goal is to complete both mizzen sails. Attach them to the yard and make all the rope, blocks and stuff that is needed to hang them on the ship.
After completing the paper cloth and shape I started with the bolt rope and cringes. The easy part are the edges of the sail.
The glue you see next to the bolt rope will in a later moment be removed and it is almost gone by now. Not all, not possible. But invisible for the eye. Only the macro pictures show it.
The cringes or is it cringles? are a bigger problem. Making them how it should be done is difficult and I can't get them on the bolt rope on a decent way. So I searched something that looks good, but not entirely correct. I made tiny grommets. They just take me 1,5 minute to make. So easy for me. There a tutorials on YouTube about how to do it.
Then I attach them to the sails
I'm happy with this tiny sail, the cringles look good this way. Maybe I change the way to do it on the next one. But For now I go on to the next part.
Reef points.
They always look bad on modelships. The rope is always pointing in the wrong direction. John Harland also wrote it in his book. But I'm working with poly rope and you can program the shape with heat!!!!! I have a tiny soldering iron for repairing 3D prints or do wood burning. I set the temperature to 180 degrees Celsius (lowest). And carefully I shaped the rope with success. The first one is ready.
The holes in the paper sails are drilled with a tiny drill for electrical boards, These are no drills like normal but more like end mills. See the first pair of pictures.
Thanks for watching.
View attachment 533698View attachment 533699
View attachment 533700View attachment 533701View attachment 533702View attachment 533703View attachment 533704View attachment 533705View attachment 533706
View attachment 533707View attachment 533708View attachment 533709View attachment 533710
Reef points.
View attachment 533711View attachment 533712View attachment 533713
By every step they look better and better, Stephan. Nicely detailed.
Hello Stephan,
I really like what you're showing about making rope crommets.
Until now, I had no idea how to make these crommets in miniature. As you impressively demonstrate, it's definitely possible to make them in a tiny version.
You need a lot of these rope crommets on a model sailing ship. For example, on the yardarms, as supports for the other rigging elements. So far, I've cheated a little and simply made a ring out of a rope and glued it at the cut points.
In the future, I'll try Stephan's method.
Hello Stephan,
Thanks Johann, great to teach the master ;)
They are one of the easiest things to make. Just turn them into each other. There is one way to turn that the rope comes together. Turning the wrong way and nothing is happening. I made a lot of them.
But you need polyester rope that had a heat treatment. I think silk is not possible to use for. And when you cheat in a correct way, nobody will see.
Splendid work Steef. Amazing at that scale.
Where did you find that cringles were circular? Herman Ketting shows a different shape in his book Prins Willem:
Thanks Ab, you are absolutely right about this point. I mentioned in my post before
I didn't get them in a nice way onto the boltrope. It keeps looking messy. That's why I choose the grommets, they looked the best of all. Yeah I'm ashamed about it, but to small for correct details.
The bigger sails will give me a better try, because of the bigger rope on the sail. Circular cringles are used on modern sails these days. They are placed in the sail.
The next small sail I make, I will try to don't let them look round but oval by sewing them on 2 points first and then the middle point. And the main and fore sail are big enough to give more detail.
