Thanks for the info Roger. I have not fully made up my mind on sails yet, but I don't think I will add them. I have considered full sails, just topsails, and possibly furled sails. I have some time yet before the decision needs to be made. If I go with furled sails, I am considering silkspan cut to 1/2 or 1/3 length.Nice work. If you do plan to eventually add sails, Sewn cloth sails are WAY overscale. Several years ago, I compared various thickness of fabric with some #10 cotton duck canvas left over from a canoe rebuilding project.
Results (Thicknesses in inches)
#10 canvas- O.034”
At 1:76 scale = .00045”
Muslin cloth .008”
Washed drafting linen .005”
Rice paper .002”
Very fine cloth at 1:76 scale is, therefore, 11 times too thick compared with heavy cotton sailcloth.
Likewise the weave in any woven cloth would be too coarse and any stitches too big.
Rice paper is still 3.5 times as thick but at least you would avoid the coarse weave ans oversized stitches.
Roger
Have you tried SILKSPAN?Nice work. If you do plan to eventually add sails, Sewn cloth sails are WAY overscale. Several years ago, I compared various thickness of fabric with some #10 cotton duck canvas left over from a canoe rebuilding project.
#10 canvas- O.034”
Muslin cloth .008”
Rice paper .002”
Roger
This is one process where a milling machine or mounted bit in fixed drill with moveable table would work out more helpful. After clean up and painting it won't look bad at all under all the rigging up front.The steps on the bowsprit looked to be daunting at first but ended up not being quite so difficult. I clamped the wooden strip to the work bench and then used triangular files to cut in the steps. Not perfect, but acceptable. The steps are shown on a "faux" bowsprit and not glued in place.
View attachment 530589View attachment 530590
Thanks for the nice comments.Great job on the bowsprit. Do as much rigging off the model as you can to make things easier.
I dreaded working on the stern blocks but finally worked on it. I made a significant error here in that I failed to realize that I the piece placed above the carved blocks needed to be cut thinner than what was supplied. After a lot of sawing, cutting and sanding, I thinned it to (nearly) the correct thickness.
The laser cut stern pieces were next to be installed. As can be seen in the photo below, one of the laser cut pieces does not have a correctly formed slot. I clamped the "bad" piece to the correct piece and filed out the slot to the correct size. I really like Mode Shipways kits, but I find it irritating that after all of these years, the company has not corrected a well-documented error such as this. I guess in this case they figure that if you can build this model that requires making all kinds of pieces from wood stock, then you can fix such a simple issue without any problem.
