HMS Agamemnon by Caldercraft
In the meantime I will try to glue the broken piece
I wouldn’t worry about that break. A modern wood glue - Tite Bond III is my current favourite - will provide a sound repair. Use some parcel tape to cover a slab of solid timber, or 25 mm mdf, or the bit of plate glass you do your sharpening on. Make another tape covered cramp pad, then lay your part on the anvil, apply glue - only enough for minimum squeeze out, carefullly cover with the pad and use a decent cramp to apply pressure, always ensuring alignment as you do so. Practice doing so dry.
Clean up once the glue has dried. I allow 24 hours.
The guns on the lower deck are dummy ones. You actually need to attach the supplied guns to the plates.I am considering just closing the lower gunports.Is this a good idea?Please let me know.
What are you modelling?
Is the ship in transit - all ports closed
Having a spot of training - one side of one deck open, and lots of people standing around for the entertainment.
About to go into battle? A broadside loaded and all ports open?
Most of the time, most of the ports would be closed. Showing a model with all guns run out is impressive, but a bit false?
You show it the way that feels right to you.
J
I received today some new tools (which I need eg Proxxon TBM220, the KT70 and same additional devices).
But, after opening the box of the Bench drill, I saw a broken on-off switch that was dangling loose in the box..
Hmmmm, so returning the drill to the Netherlands....
This is a simple matter to replace. A similar toggle switch can be found on Temu.com or at any electronics store in your area. Once you have a new switch,replace the two electrical contacts with copper crimp terminal or spade connectors depending on the contact type on the leads going to the main switch housing or simply resolder the wires to the switch terminals directly. Very inexpensive fix but don't try and ruse the old switch!
Gentlemen,
I would like to have your opinion on the following:
I would wait until you can see what the difference is. If the gun port opening is big, and the dummy gun looks bad, then you can make a clear decision.
Hi Marc!
Are you forming the rabbet before gluing on the keel? Probably easier to make the varying angle of the rabbet if done before gluing to the plywood back piece. With only the knee of the head and no actual stem on the kit model, cutting the rabbet at the bow is going to be interesting :) Assuming the plans show the line of the rabbet where the stem would be, instead of tracing the line, can you scan the image in the kit? If you can, then you can print it in label paper then stick it on the wood and have a perfect curved line on the stem to cut the rabbet with a scalpel and chisels. You would need a mirror image as well for the opposite side, but easily doable. Just a thought.
Hi Marc!
Good idea
Hi Marc!
Hello Alan,
You're right (as always) :) ;)
But there is a surprise:
nowhere in the instructions nor drawings is there a reference to providing the Rabbet!
If you look at the picture of the Bulkheads (Dry Fit) you will see that the bottom side (of the Bulkheads) touch the False Keel!
So there is consequently no place for the Rabbet, unless you provide it in the False Keel. And I think this is not the intention.
Just to be on the safe side I have installed the Rabbet, above the Flase Keel so that I have the necessary flexibility during the First Planking... But still strange.
Meanwhile, the Bulkheads and the lower Gundeck have been glued....
As you can see, I've covered the Lower Gun deck with Limewood strips (1x3 mm). The idea is that the deck might be visible from the higher gratings and, on the other hand, through the open gun ports. I've decided to close at least one row of the lower gun ports. I can leave the other side open as planned, but I'll evaluate this later.
I haven't seen a flat iron since my youth
