- Jan 21, 2023
when i scratch built my battleship HMS Warspite which is about 52" long, i made the skeletal frame out of 1/4" thick  & frames 1/2" wide balsa but glued in sections then carved to shape. the hull plating was made using .040" styrene sheets in long & wide pieces where the hull was flat & shorter & narrower pieces were the hull curved. used wood glue for joining the balsa pieces together & Testors tube plastic glue to glue the styrene pieces to the balsa frame & & to each other. still have the hull in 1 piece after over 35yrs.
