A quick update. The second planking has been completed stained and varnished. Lember boards and other trim pieces have been installed. Still need to install the rudder, but I hate gudgeons and pintles, so I'm procrastinating. I'm happy with how it's going so far, but there are several things I did wrong and hopefully will correct on my next ship. First off, there is a very slight twist to the frame which I didn't notice until I had the bulwarks attached and had already started planking. Next, I did a good job of fairing the bulkheads but did not adequately fair the added blocks at the bow and the stern. This resulted in a fatter than normal stern and a more rounded bow making the final planking less than perfect. Then I learned a lesson of not cutting stick lumber to what I thought was the correct length but cut it slightly longer and then sand it to proper length. Still have some sanding to do on the gun portals. I have just started on the deck furniture which leads to my next question.
I've just started work on the cat davits. The directions specify holes to be 0.5 mm but these seem to be much too small. Are these accurate?
Here are some current pictures of my ship:
