- Dec 1, 2016
Looking at the green spot at the start makes you wonder how will all this flow together? The rough chunky build once sculpted and finished it does all come together with tight joinery and a smooth flowing shape.
This is why the shaping of the hull stops short of the final shape and finish. once the stern is tied into the hull is when you sand the hull to it final shape. By not shaping the hull bulkheads or frames depending on your build, it give you that little extra material to blend everything together. The block at the bottom is now nicely shaped and a perfect backing for the end of the wale.
