- Jun 28, 2020
Hello Namabiiru,I'm guessing it's to keep the bowsprit over the base, and thus better protected from getting snagged by a passing sweater of set of golf clubs.
You're right.
Hey mellpapa, "G.o.a.t" = Greatest Of All Time.Hello, ConsNZ.
Here, people who are skilled at crafts are called “Goats.”
I see, thank you for letting me know.![]()
Hey, ConsNZ!Hey mellpapa, "G.o.a.t" = Greatest Of All Time.![]()
Hey, Namabiiru.Mellpapa, your ocean and sails look wonderful. Do you intend to die the sails? Maybe with tea or coffee?
Hello, GIG1810.Hey Mellpapa,
that looks very good. The sails too. But if you use the clear varnish, you have to be careful when you spray it on the fabric. It may come off again partially if you move or press it. It won't look so nice. Unfortunately, I experienced this once and the piece of fabric could no longer be used. That's why it's better to use textile spray paint. That's better!
Best regards
Günther![]()
I wish I knew about this technique before! My St Gildas would have turned out much better. Thank you for sharing it!View attachment 539379
When I sew vertical lines with a sewing machine, it creates fine wrinkles.
I want to fix this somehow.
I'll try using clear lacquer spray.
I'm shooting with a strobe, so the wrinkles and bumps are flying off white.
This is the main top gallant. It is wrinkled and bumpy like this.
Spray it with clear lacquer spray and let it dry.
Repeat this two or three times, and once the clear lacquer spray has dried and hardened...
Place the main top gallant sail between two sheets of Construction paper and iron it.
Surprisingly, the wrinkles and bumps disappeared.
I had predicted that this would eliminate the wrinkles, but I wasn't sure.
So, I decided to try it out.
It worked.
This is the main top.
This is also wrinkled and bumpy, but if you put it between two sheets of paper and iron it...
As you can see, the wrinkles and bumps disappeared as if by magic.
This is the main lower part.
The red line indicates where I ironed it.
The unevenness is gone.
I ironed the entire main lower surface.
The unevenness disappeared.
I am going to apply a decal of a fierce double-headed eagle to the main lower surface, and if the base is uneven, I won't be able to apply the decal neatly.
As expected, you never know until you try things like this.
I'm glad the unevenness of the sail is gone.
The three sails are now smooth and crisp, with no wrinkles or bumps.
It's as if they've been ironed with starch. I will apply a thin coat of Mr. COLOR's Sale Color and Neutral Gray/German Gray to give them a weathered look, but I will do that tomorrow.
I need to purchase Mr. COLOR's Sale Color No. 45.
Now, it's off to the model shop!![]()
Hey, Namabiiru!I wish I knew about this technique before! My St Gildas would have turned out much better. Thank you for sharing it!
The next time I make ship with sails I will try it! I don’t plan on sails for the Fair AmericanHey, Namabiiru!
If you're planning to make a model sailboat, sew the vertical lines of the sail with a sewing machine, and if it gets wrinkled and bumpy, use clear lacquer spray and an iron to fix it.
Today's experiment was really useful.
If you want, you can try it yourself, but do it at your own risk.![]()
Hey, Steef66.An old lady nearby who makes bridal wear by hand. Who told me that you should always iron the fabric before sewing, this prevents the fabric from wrinkling while sewing. Also setting your sewing machine to the fabric you are using is important.
I agree with Mellpapa that the issue seems to be thread tension, which I have yet to master. I ironed mine multiple times before sewing, but still got the wavy effect Mellpapa showed.An old lady nearby who makes bridal wear by hand. Who told me that you should always iron the fabric before sewing, this prevents the fabric from wrinkling while sewing. Also setting your sewing machine to the fabric you are using is important.
To my wife her sewing machine was precious. I asked her to sew the sails for La Nina. She agreed then saw what had to be done and said 'I'm gifting you the sewing machine'Hey, Steef66.
Thanks for teaching me how to prepare the fabric before sewing.
I dyed the fabric lightly with coffee, let it dry, and then ironed it.
I didn't know that you had to adjust the sewing machine to the fabric.
I've never used a sewing machine before, so I asked my wife to do it for me.
My wife won't let me use the sewing machine.![]()
Hey, Steef66!Yeah, you have to be a professional to use that machine. That's why I use paper now for sails.
Hey, ConsNZ!To my wife her sewing machine was precious. I asked her to sew the sails for La Nina. She agreed then saw what had to be done and said 'I'm gifting you the sewing machine'![]()
