Pavel Nikitin Oseberg #3 kit #61
My go to glue for shipbuilding is "Titebond II". I've become the Master of "Do-Overs". Somewhere I read about using vinegar to loosen glued parts versus using a heat gun or hot water. So.....
I applied a thin bead of vinegar along the glue seams, waited a few minutes and carefully pried the parts apart.
You should test the vinegar on a piece of scrap to see if there is any reaction.
Jan
Hi Jan,
Thanks for the tip. I've heard about the vinegar thing, I was always worried about it discoloring the wood. I'll give it a try, if it worked for you I'm sure it'll work for me.
I ordered the mast step upgrade from Pavel as well, hopefully the tariff thing doesn't delay our delivery too much.
Steve
