Good idea.I'm no chemist Namabiiru, it sounds like your Japanese fuel alcohol is a more powerful solvent. Glue a couple scraps together and test its solvent power, it may be way better than isopropyl, who knows?
I have been using Titebond III on this build because it's what I had on hand. For that reason, I thought it was going to require a judicious application of high explosives to get the bulwark planking off, but you were spot on about the rubbing alcohol.Yellow carpenters' glue is a different animal than white glues. Formulated for carpentry, it has a very limited set time after which it is strong and stubborn as hell.
I have no idea as to its' reversibility. it also has a limited shelf life. For these reasons I abandoned it early on for furniture restoration, and ultimately model building.
Others I've seen here like it for their own reasons.
) for about half of what it would have cost new and with no shipping charges.
Paul, thank you for your very kind words, but I can tell you put 20 parts of research and 20 parts of thought into it before you do 1 part of building. I just dive in and make it up as I go along. Sometimes the TLAR method works, sometimes not…Excellent sleuthing. I've been staring at a transom for a while now as well. I'll hope for your same level of insight...
Thank you, Günther. I don’t know how much there is to learn here, except what NOT to do, but thank you for coming along.Hey Namabiiru,
I am so curious about your construction of the Fair American .
I'll definitely stay loyal and learn from you! It all looks very good so far.
Cheers, Günther![]()
Thank you very much. I foresee that band saw getting lots of use.Looking great so far! But I'm a little jealous of your find.
Many thanks, Peter! Coming from you, that is high praise, indeed!Bunk and water closet if they look believable and solve the problem.
Some nice craftsmanship and wood working!![]()
Thank you so much! I’m pleased with how it is turning out so far.Kaaa these look so cool!!! I love seeing the transoms come together. They look so detailed and pretty
