Apparently the attachment editor doesn't work on my phone--only on the computer.
They were pretty thin, Roger. I scraped it off and redid it with some success. If I went on bare epoxy that I had sanded, no problem. It was only on the primer that it puckered. I would have thought it would be the opposite effect.Try thinner coats.
It is an enamel spray. If I sand first, it doesn’t seem to be a problem.I use automotive primer for most everything, but I have found some brands leave a texture like 120 grit sandpaper, or the stuff I get at the local auto store here that seems to need a super thick coat to get complete coverage.
One question: are you shooting acrylics over the primer, or enamel?
Most curiousIt is an enamel spray. If I sand first, it doesn’t seem to be a problem.
Good morning Vic. Wonderful progress, she looks very cool. Looks like you have a balsa puzzle ahead of you...I’m building the superstructure now. Who knows what part goes where? I have a few pictures and instructions, but most of the numbers have worn off.
View attachment 548293View attachment 548292
I really do have a balsa puzzle. I’m isolating larger pieces I can identify and placing them in containers that have parts for the four levels of the superstructure. After I have sorted them out, I’m hoping I can suss out the smaller parts that fit. If I can’t, I may have to manufacture some little pieces. It will be an adventure, Grant! Thanks for following.Good morning Vic. Wonderful progress, she looks very cool. Looks like you have a balsa puzzle ahead of you.... Cheers Grant
What kind of primer was it? I've recently had something similar happen with Rustoleum 2XI then sanded the primer down to where it was bare in spots and got rid of the problem areas. I don’t think I’m a fan of this primer.
That was it!What kind of primer was it? I've recently had something similar happen with Rustoleum 2X
