- Jul 11, 2023
It’s good that you got the (little) misalignment in view at this early stage. And can start with the build again.Keel assembly (part 2): <<A WORD OF CAUTION HERE >> I came across a small set back. Something I should have thought about but did not. I dry fit parts 10-15 thinking that the following with be then ok. Wrong... once dry, I tried to align part 18 and, of course it was off. The junction allows for a little bit of play. If not very careful the assembly at the far end could be ever so slightly off (upward by even couple mm), which will throw off the alignment down the road. I'm not happy with the work so far... so decided to go back to square one.
Luckily, the whole thing could be disassembled easily with hide glue. Hot steam vapor is enough to loosen the bound and separate the parts without any damage. The glue is them wipe off with a hot water rag and the parts back under press until fully dry. I will be going back to dry fit (including part 18-22) and deciding on another gluing strategy.
