Good afternoon Rob. Nicely done. Cheers Grant
Thank you for the kind comment Grant! This kit has been fun and I am really learning a lot.Good afternoon Rob. Nicely done. Cheers Grant
Beautifully done.After delaying about as long as I could I finally stepped the mast onto the hull section.
The lower mast is supported by 6 shrouds, 5 are connected with deadeyes and the 6th called the swifter, is attached by a block and lanyard system. This gives it easier adjustability than the other shrouds.
The instruction would have you use a triple and double block for the swifter, but after seeing the discussion by Tom Culb, I decided to follow his advise and use 2 double blocks. The most forward shroud attaches to a deadeye then goes up around the mast and goes forward as the swifter. Since I believe this element of the ship will have a lot of visual impact, I rigged the block and lanyard using the model expo beautiful blocks I had. You can see they are a step up from what I used on the cannons. I also used the rope of scale 0.5mm (0.019" line). One of the blocks was seized to a hook. The other block I made a loop at one end by wrapping a line that will be used as the lanyard around a drill bit. I then seized that and seized a block to that. the long end of the lanyard was then run through the blocks.
Thank you for your kind words!Beautifully done.
Why have you left out the Gun Tackle? It would be necessary to run the guns out. Is it because the blocks are so far out of scale? I had to cut down some of the blocks to get them to fit. In my model, I noticed that the carriages for the long guns are too large, and the carriages for the carronades are too small; or the guns themselves are out of scale.I finally installed all the cannonades. for some reason the breaching line for the last one was just a fraction too small to fit. I had to replace it. Replacing it was a little bit difficult and it brought home how much easier it is to do the rigging for each piece of armament separate from the ship itself. I know I would have had a much more difficult time with all the lines and would probably have damages pieces of the ship.
You are correct I left out the gun tackle. I found the deck already too full and as you said the blocks are way too bulky. I have recently gotten much better blocks from model expo, syren models and Dry -Dock models. They are much better looking and I will be using them on the mast and yards.Why have you left out the Gun Tackle? It would be necessary to run the guns out. Is it because the blocks are so far out of scale? I had to cut down some of the blocks to get them to fit. In my model, I noticed that the carriages for the long guns are too large, and the carriages for the carronades are too small; or the guns themselves are out of scale.
Thank you!Enjoy your vacation, Rob!
The "extra" eyebolts may be for tarps for shade or other tie-downs we do not know about,The instructions would now have you do the cap rails that have the hammock stanchions and netting on it. These PE hammock stanchions are very delicate and I know I will be bumping and bending them into useless pieces of plastic and metal in no time. So while I may assemble them now I will not attach them until the end. NB Now in the process of rigging the ship I HIGHLY recommend that you do NOT install these until after the ship is rigged. They will only get in the way. Using 1/8 X 1/4" strip they want you to cut a double round profile on the outside facing surface. This is way above my abilities, so I just rounded the outside surface. Instead of 2, I made the cap rail twice as long to make it easier to handle. I drew the lines where they want the stanchions in mirror images going from the center. This, when cut, will produce 2 cap rails aligned the correct way port and starboard.
They want you to put eyebolts on the inside surface of the cap rail. I am not sure why these eyebolts are here. I don't see them used on the plans but they may be used for the rigging so I will include them. Beware one picture in the instructions shows them installed on the outer surface of the cap rail also, but I can find no evidence that they belong there. So using my trusty pin vise I drilled some holes in the inner side of the strip to attach eyebolts. I also made holes in the center of the top for the hammock stanchions.
After the eyebolts were in place I painted the cap rail black.
