- Oct 1, 2023
Thanks, I intend to scrape vs sanding.Good evening Ted. Your deck is probably lime as it a Occre kit. You can get the lime looking really cool if you don’t make the caulking tooo dark. A HB pencil is what I used on my Xebec. I found if you scape the lime vs sanding also brings it out rather nice. Once you apply a finish to it, it comes out rather nice. Cheers Grant
Thank you, I'm going to make a mock up and test it.I'm coming to the world of ship building from some experience in cabinet making, so I hope some techniques will carry over. When it comes to wood finishing, this principle will definitely carry over: if you ask 10 woodworkers how to finish an item, you'll get about 30 options. We each just have to pick a procedure that we like.
For a polished wood finish, I hand-sand from 240 grit to 400 grit; apply shellac sanding sealer; allow to dry (10 minutes), sand and seal again and sand... then apply clear furniture wax, allow to dry (10 minutes) and bring the best shine up by polishing with some soft cloth. That will bring your wall up to a soft shine and although I've made it sound up and rest itlaborious, it actually only takes a few minutes over the course of any hour.
However, this approach wouldn't work if you ever intend to then attach anything to it- this wax finish is almost totally resistant to all glues.
Just a suggestion. Don't put a light underneath the decking of the ship!I just snapped a photo of the deck planking. It is so thin you can see light through it. IMG20251109061306.jpg
