Proxxon MF 70 | Upgrade Tools Jigs Workspace | Making: grating ladder stair skylight pin carriage pump windlass winch mast yard
Ukraine, Kyiv
In this thread, I'll be showing the following:
1. Machine upgrades and improvements (Z-axis bearings, electronic ruler, lighting etc.)
2. Consumables I'll be using (milling cutters, drills, burrs) and jigs I'll be creating for the job.
3. Workspace and storage (designing a box and a stand-drawer).
4. Machine operation and making: gratings, ladders, stairs, skylights, pins, carriage pumps, windlass, winch, masts, yards, etc.
N.B. information will appear as I implement this.
There's a large thread on the forum that might be useful for you too - Can you get the most...
I highly recommend watching it! It's full of useful information.
Thanks to @Jimsky there are also several tutorials: Making: gratings | carriages | cannon trucks | Pawl Rim | calibration.
In this thread, I want to collect everything I'm planning to do with my Proxxon MF 70 so the information doesn't get lost in the numerous pages of build reviews.
I hope you find it useful.
And first of all, I'll show you step-by-step instructions on how to install bearings on the Z axis,
which is the first and most important improvement to this machine!
These bearings can be ordered on AliExpress using this link.
It's important to find the exact size.
Be careful not to move the cylinder with the scale; there's a locking device there that could pop off and get lost! This will need to be done at the end.
There's a black cylinder with fractional mm markings under the rotary knob. This cylinder needs to be moved away from the knob. But this needs to be done last, otherwise the pin that holds the cylinder to the axle might come loose. I wrote about this after the picture with the "Attention".
To avoid any friction at all, you can slightly raise the scale cylinder (but this is not necessary; if the scale is very dirty, you can cover the bearings from dust).
To install bearings on the other two axes on the coordinate table, to avoid repetition, here is a thread with detailed instructions:
I recently designed and ordered a Workspace for my machine.
It's a simple cabinet with a protective storage box.
I'll show you the finished product when it's ready.
I will also indicate all the dimensions and sizes to create something similar.
Hey Sergey,
Wonderful, now I'm curious. I'll take a close look at your reports on the Proxxon MF 70, as I'll probably buy one. Thank you very much for your hard work. :D Thumbsup
Great topic, thank you.
On a new machine, it's fine and really important to put this bearings. On older, it's probably a useless rescue?
What about lifting with bearing? Lowering it is no problem. When lifting without bearing, head have feel resists.
Should be helpful to those with this machine.
Hey Sergey,
This is definitely the most important thing to do. Anyone who has ever tried without bearings understands what a pain it is. And after installation, everything is just wonderful. And tools like a saw, a grinder, and a drill are the bare minimum for a modeler.;)
I'm more than sure this will be just as true for an old machine as it is for a new one; there's no difference. Two bearings are required in any case, and it's important to tighten the nut so it doesn't wobble, but also so that rotation is as smooth as possible. The result is simply night and day—before and after.
Great instructions and pictures.
Can someone explain number 12,
shift close bearings.
Thanks
Thanks for the feedback. There's a black cylinder with fractional mm markings under the rotary knob. This cylinder needs to be moved away from the knob. But this needs to be done last, otherwise the pin that holds the cylinder to the axle might come loose. I wrote about this after the picture with the "Attention".
I remember a few years ago, a model engineer modified the hand cranks to larger diameter ones. It made the mill more user friendly.
Yes, I noticed this and am thinking about it. If it becomes too uncomfortable, I'll probably also consider replacing the handles with larger ones.
Hi Sergey, nice tutorial thus far. Will you also be adding the thrust bearings to the X-Y table? I found that was necessary as well.
Thanks, we'll continue. I haven't decided yet about the X-Y axes; there are a lot of reviews that don't help much, but it's hard for me to judge. I'll try this for now, and if it's uncomfortable, I think I can fix it. But you're the first to say the result is different, and that intrigues me.
This difference was the lessening of the play in the turning wheels. Without the thrust bearings the wheel could be turned quite a bit before the table started to move. With the thrust bearings in place that was improved (but still not eliminated). You're right to say: we'll see...
I can confirm what Paul said. The Y- and X-axis thrust bearings are more essential than the Z-axis. The Z-axis, especially when there was significant play, was very hard to turn, and installing thrust bearings made it turn effortlessly. Both the Y and X axes are crucial upgrades, removing about 95% of the play.
It's a pity I was only planning to change one axle and bought 5 bearings, but I need to think about it and buy more if I decide to install the rest.
My experience is the exact opposite. The X- and Y- axis plate was smooth as butter right out of the box while the Z-axis was very difficult to turn. Once I installed the Z-axis bearing I saw no need for the others. I guess each machine has their own idiosyncrasies.
Merry Christmas and Happy New Year!
Hi Oliver. Yes, I am certain there are variations across machines. But the issue for me wasn't smoothness - it was play. I could turn the wheel on the X-Y table quite a bit before the table started to move. The thrust bearing mostly solved this problem.
Maybe smooth wasn’t my best word choice as “play” would have been better. I have basically zero play on the x/y but even with the bearings on the z-axis I still have about 0.2mm of backlash. It’s quite frustrating to have to compensate for it.
Yes. I have the same lingering problem on the Z axis - especially when raising the cutter. Surely a design flaw. I assume better mills don't have this problem which is why I am always peaking in store windows wondering if it is time for an upgrade.
