DE 7 PROVINCIËN (1665) 1:50
This is astonishingly fine work, Herman! I believe you are doing this with just files (that is, you don't have a mill or CNC) - is that right?
Thanks Paul. You are partly right but I do have a mill but hardly ever use it. I used it this time only to mill the slots in the catheads. No CNC.
I drilled 4 holes in a piece of wood for the carvings and the rest was all done by files.
Without disparaging those who are using CNC and/or printing to build their models (in truth some of the work we see is breathtaking) - doing things by hand is the part of the hobby I enjoy the most. I see the same is true for you as well!
I certainly don't look down on those who print or cut CNC work. The results can indeed be breathtakingly beautiful, and if you have to create a row of identical patterns or figures, they are. With recurring figures, I'll spend ages working on them, and you'll undoubtedly see differences, but that's my approach and what I enjoy most.
You might want to double check your English translation Peter... Specifically... hand***
This says more about your mind then my Dutch/English……;) Hopefully I will meet you on the Dutch forum and see how you are doing there. Perhaps I will invite you to visit a coffeeshop ……:) But(t) ;) I have changed it.
PS-1: At least I’ll put my name under a post/replay, ‘Jwallkc’.
PS-2: Sorry, Herman, for this in your log.
Good job Herman and beautiful photos. CNC certainly saves time on cutting repeated shapes, but I assure you designing carvings can be as complicated as carving
Hi Herman,
Fully agree with you on this one. I have been thinking the same about switching to CNC and asked myself the question what do I like to do the most. Currently that is working with a piece of wood and a chisel, what is more relaxing than that.
CNC means the work is done behind the pc and that is what I already use too much during my work.
For hobby I'd like to avoid pc work as much as possible.
Maybe it changes in the future, we will see. For sure CNC delivers outstanding results which are nearly impossible to achieve by hand but hand made carvings are putting an additional soul into your build.
Thank you Wojtas. I am 100% certain you are correct. I wouldn't know where to start, have zero experience computer designing, so in my case most manual carvings would even be quicker than starting from zero learning to design the carvings on the computer.
Everything has its learning curve. Founding new function in program can be satisfying too, especially when you learn to make a armor or a cloak
I even wouldn't go with CNC. Resin prints are enough for me. My fried @Mirek painted this korbel with shelac. If somebody is not so strict about material why go so expensive with CNC milling wood for ornaments
