Sterling American Scout WWII Cargo Ship
They look like an L-shaped piece of lead. I do like the fact that they have some ridges like the real ones have. On the hatches, make sure the rectangular supports for the hatch covers line up with the hatch holes. Mine don’t fit. I’ll have to remake them.
Thanks for the advice on the hatch covers, I'll pay extra attention to that detail.
A magazine article on the kit shows these custom peaked hatch covers. They've got real fabric covering. I don't know how common peaked hatch covers were but they look nice in spite of the poor quality of the photos in the magazine...
More about the magazine article in the next post...
While assembling the bulkheads, I discovered that one piece was missing. It wasn't a problem because it was a mirror image of the same piece on the other side of the same bulkhead, so I traced the one I had and made a copy out of 1/8" balsa. And when doing the shears, another piece was missing. It also was a mirror image of the same piece on the other side so I just made a new one.
The other day another Scout kit came up on eBay so I made an offer that was accepted. I bought it just in case other parts might be missing later in the project that weren't so easy to duplicate. This other kit seems to be untouched and complete, including the optional hardware kit. Unless my current kit is missing a part I can't reproduce, I'll leave this second kit intact and once I finish my model I'll sell it since I don't need two of these ships.
A few interesting things about this kit compared to my other one - notice the lifeboats, one is on top of the fitting kit box. They're carved balsa. The lifeboats on my other kit are vacuum-formed plastic. There's also a brochure from United States Lines promoting trips one could take on a cargo ship. All of the wood parts are still in the sheets they're stamped from, so it's unlikely anything is missing.
The kit also came with two magazines with articles about the Scout.
I'm finishing up a home project tomorrow morning so hopefully I'll be able to get back to ship construction in the afternoon.
Added a plywood base today. It's shaped to accomodate the wider bottoms of some of the bulkheads resulting from shortening the bulkheads.
Why is the hull on the table saw? Because about 60% of the hull is straight and the sides are parallel, so I put the hull on the saw to set the rip fence to the correct width; this way the sides of the plywood will be straight and parallel.
Cutting:
Then I traced the outline of the bow and stern portions of the hull - I traced at the outside edges of the bulkheads, which because I shortened them at the bottom, are wider than the balsa base. Rough cutting on the bandsaw:
Final fitting of the plywood to the hull; an angle die grinder with a 30-grit sanding disk makes quick work of finalizing the shape.
A view of the plywood base showing how it's wider than the balsa base provided with the kit. The plywood is as wide as the bottoms of the shortened bulkheads.
Because the deck pieces aren't a perfect fit I decided to glue them in place now so I can fair everything together before sheathing the hull. I also added some longitudinal 1/2 x 3/4 pine stringers inside the hull to stiffen the plywood; since it's only 1/4" plywood and is a bit flexible the stringers stiffen it so the assembly won't flex. Everything clamped and weighted:
The next step will be final fairing of the hull followed by sheathing.
That would be cool to have a copy of.
Fairing of the hull is done. Time now to add the sheathing/planking. Question for Vic (or anyone else who has built this kit)... the instructions say to wet the outside of the wood to help it bend during application to the curves - how much water did you apply, how did you apply it and how did it work out?
If if looks like the deck is bulging out to the side about halfway back that's not the case, it's a result of the photo going out of focus - my cell phone camera doesn't have that much depth of field for photos this close. I actually faired the straight section of the hull on my 6x48 belt sander so they're definitely straight.
I don’t remember wetting the planks. They bent pretty easily. I had some problems with the sheathing on on side, but I wound up cutting the problem area off because it was at the bottom. Most ships I either wet or steamed. I would additionally use wood glue with a spot of super glue on the ends. Then I would use an iron to set it. I didn’t use the iron on this one. Probably should have. I had a lot of trouble with using pins as suggested to hold the strakes in place. There are plenty of curves on this one. It would be easy to sand too much off. Most people wind up using a lot of putty.
I decided to wet the outside of the balsa side panel per the instructions, I figured they wrote that in the instructions for a reason so why not try it. Turns out water in the correct place warped the balsa in just the right direction and softened it a bit so it was very easy to curve it. Before clamping:
The instructions say to use pins to hold things in place but I decided clamps and some masking tape would work better. The masking tape works great along the water line because it can grip well on the flat bottom of the hull and the flat side, I doubt tape would work well if built with the full hull.
I'll get the large piece on the second side done today and get back to the rest of the sheathing after Christmas.
remember to alternate sides when gluing the hull sides to the frame as doing 1 side complete before doing other side might cause model to twist & warp.
Thanks, I definitely plan to do that. You can't see these in the photos of the side clamped up but the hull is sitting on a perfectly straight oak board and there are heavy metal weights inside the hull to keep it flat on that board while the side dries. I'll do the other side next and use the weights inside again to keep the hull flat.
My clamps caused indentations in the sheathing. I had to go back and use a heat gun to make the dents pop back out.
I'm in the process of applying the sheathing to the hull and some of the pieces have been hard to clamp in place because of the bends. I use masking tape in some instances but some places need a little more force so I'm using small "QuickGrip" clamps, I've got a bunch of them in my workshop. They work very well on more-or-less parallel surfaces but often slip on the more angled surfaces. I'm sure veteran model shipbuilders have great solutions to this problem, but I'm not a veteran ship builder so the way I get my QuickGrip clamps to stay in place is to put a small piece of double-sided tape under the feet of the clamp. A piece is visible under the clamp foot at the top of the photo. It works very well and doesn't stick permanently to the balsa or the clamp so no damage is done. FWIW.
I’ve al
I’ve also glued sandpaper to my clamps. And I’ve used scabs of wood to get a grip on. Is that the aft section? I don’t recall any sheathing there.
Yes, it's the aft section. I probably should have used the work planking instead, although the starter piece that's clamped in place is a wider piece that was scrap cut off from the side sheathing.
I remember those moments. They weren’t my finest. Looks like you’re getting a lot of reads. Good job!
My main reason for starting this thread was so that I would have a place to ask questions. I've built many things, but this is my first ship model and already the answers to the questions I've asked in this thread have been tremendously helpful, so thank you everyone who's given input here. I'm sure I'll have a lot more questions as I get further into the construction, so hopefully the people reading this thread will keep reading and be ready to answer questions!
I don't presume that I'll have many tips to offer to a groups like this with so many expoerts, but if I do have what seems like a good idea (like today's double-side tape post) I'll share it. That's my usual mode for participating in forums, in other venues such as Jeeps and offroad trailers/campers I've done a number of project build threads in which I post tons of detail so people can learn by following along. A number of those threads have had more than a million views and in at least one case over two million, but in this thread I'm the novice who needs to learn, not the expert/advice-giver.
Making good progress on sheathing/planing the hull, but the weekend I think the basic hull will be complete.
I used a finger plane as well. It did a good job, but the strakes got a little thin in spots.
I had a finger plane a long time ago but since it doesn't figure into the typical projects I do I have no idea where it is now. Probably would take longer to find it (if I even could) than it will take to smooth the hull with sandpaper :(.
As I was planking the hull over the last few days I was reminded of a similar project I did some years ago. I was making mold masters for a new design fiberglass hardtop for Jeep Wranglers and I built up the curves with strips of pine and hand planed them to a smooth curve. If you look closely at these work-in-progress photos, you may be able to see the strips making up the curves on the sides. The flatter parts were skinned in birch plywood and underneath was a frame not unlike the bulkheads that might be in a ship or boat.
I'm working on a much smaller scale now with much softer wood but it's very similar to the hardtop project :).
The mold made from the wooden master worked out very well, wondering if I should make a mold of this model hull to make hulls in fiberglass...
You’ve got some skills there, Jeff!
