Sterling American Scout WWII Cargo Ship
On a general cargo ship there will be four spot lights located under the cross tree or upon the cross trees.
They would be aimed at the deck space between the cargo hatch and the ships side.
There are lights in the hold to accommodate lighting requirements below decks.
There are also cage lights along every deck structure ( usually about 10 feet apart) to accommodate night time lighting requirements for manpower moving about the decks.
None of the deck house(s) cage lights would be located in such a way as to shine into the wheelhouses forward facing windows.
And those peaked hatch covers from the magazine article…..
That’s not true to life.
Hatch covers were always flat, covered in heavy tarps, steel strapped and secured to the hatch coming.
A peaked hatch cover would have been impossible to keep watertight.
He probably got the idea by seeing a rain tarp hanging over the open hatch.
Rain tarps were hung to keep cargo dry if it was raining while cargo operations were in progress.
Thanks for the info, very helpful!
I've got these lights with LEDs that I may use in the few places on the deckhouse where floodlights might be used. I'll have to see if I can find HO scale cage lights, I don't think I've seen any before but maybe they exist. I'll also look for floodlights that might go on the cross trees.
I found these spotlights in HO scale from a number of sources, maybe these would be good on the cross trees?
Hull sheathing/planking now done and rough sanded smooth. Probably will do some sort of filler to get everything perfectly smooth. I used some Deluxe Materials Model Lite Balsa Filler near the bow and it works pretty well. I didn't like the design of the bow where the planks from both sides would be glued together, seemed like the point of the bow would be fragile with the soft balsa so I added a stem in front out of pine. More sanding and filler required before I'll call the hull done but I'm happy with how it's coming along.
Looking smooth so far. I like the idea of a piece of pine at the bow. It will look straighter that way.
Got back to the project today, the hull is sanded and some filler has been applied to smooth the shape. Next up will be several coats of sanding sealer followed by several coats of high build primer. High build primer is used in automotive body work as a step in perfecting the smoothness of the surface for painting; it goes on fairly thick to fill imperfections and sands easily. Maybe it's not a typical step to finish a model ship hull but I've got lots of experience with it in making molds for fiberglass automotive parts and in putting final paint finishes on the pasts from those molds and I've always gotten excellent results with it.
A nice job building the hull! I particularly like your shaping of the “cruiser” stern.
Roger
Thank you very much! We'll see if I've done a good enough job when I spray it with the primer - having everything one uniform color usually highlights areas that need more refinement. I'm expecting a little more filler work to get everything perfect.
Here's the hull in high build primer. It looks great in these photos but on very close inspection there are a few areas that are not perfectly smooth. I've been using a filler putty intended for balsa work and haven't been completely satisfied with it - it doesn't spread as well as I'd like so it's very difficult to get a consistent thickness of filler where needed. I'll resort to an old standard I've used for many years making fiberglass molds, a very fine grain, easy-sanding polyester body filler for automotive work. It's soft - about as hard as the balsa is with the sanding sealer and high build primer applied, and spreads very consistently and it feathers extremely well when sanding, so it'll smooth out the few areas I'm not happy with very nicely.
I wish I had known about that type of primer earlier. The deck could have certainly used it. I’ve tried several types of putty and haven’t been happy with any of them.
The grain in the plywood deck might be too deep for high build alone to fix. When I get to finishing the deck I'll post what I learn.
This morning I did some "auto body work" on the hull; using skim coats of polyester body filler I smoothed the inconsistencies in the hull. Everything is perfectly smooth now and ready to be shot again with high build primer. The process was:
1. Apply a thin coat of filler to the area in question. The automotive body filler I used spreads very easily in a thin skim coat; I use old credit-card sized hotel room keys as spreaders
2. Rough sand with 80 grit
3. Finer sanding with 150
4. Apply another coat if/as necessary. If you look closely at the photos the slight variations in color of the filler indicates where multiple applications were done.
5. Repeat steps 1-4 until satisfied
6. Finish sanding with 240
The filler I used also sands and feathers very easily so the sanding process is pretty quick.
While sighting down the hull to see if everything was lining up properly during the final sanding I was disappointed to notice that due to the top of the bulkhead at the front of the poop deck not being perfectly level, the poop deck was sloped slightly to starboard. I fixed that with body filler, check the left side of this photo and you might be able to see how the filler raised the starboard side of the poop deck.
In this next photo you can see how the filler tapers to nothing on the port side.
It was a very quick fix. My point in posting this as a response to Vic's post about the grain on the deck plywood is this - after doing this I'll plan to skim the entire deck with filler to eliminate the grain and create a deck surface that looks like metal.
