True storyThis is some truly beautiful work, Sergey! You have a rare gift!
Thank you, friend.True story
Thanks for the praise.Your gratings are really fine!! Do you know if the outer ledges were ever cut half way to accept the battens as you show, or totally across, or were both methods used at times? Pictures below. Up to now I had only seen them as in the drawing on the left and the last two pictures below but what you show looks structurally sound as well.
Many thanks
I am not so sure White is correct as I could not find any contemporary based information anywhere that gratings on large or small vessels had the design White shows. Even so, there were very few things where the words "always" or "never" in the ships in the days of sail applies so I would not be surprised if two designs were used.There are at least two types of gratings: a simple one (the one you showed) and a more complex one with the slats embedded in the sides.
Awsome!2/3
So, let's continue with the front grating.
First, we need to make it arched at the bottom.
I'll round the top surface later, but for now I'll make the frames for both hulls at once.
I'll mill all four parts (the front and back of the frame for both hulls) first flat, then along the edge to assemble the frame.
Then, using the width as a guide, I measure how to mill the side parts of the frame (for both hulls at once).
When all the parts were ready, I glued them together with liquid CA.
After that, I used a sander to cut off the excess on the sides.
Now it was necessary to trim the sides in the side parts and it remains to fix the two parts (but this is in the next part), but for now this is the result I got when I inserted the grating into the frame.
Besides that, there are two parts left to glue to the frames, but they still need to be given a semicircular shape, but more on that in the next post.
Thank youAwsome!
Thanks for the congratulations and best wishes, my friend! Yes, a lathe is a must-have; it's impossible to achieve such precision without one. I was planning on making the front grating open in the frame, but I wasn't sure if it would work, but now I realize that with a milling machine, anything is possible.Hey Sergey,
I wish you and your loved ones a happy new year!
I see you've been putting your Proxxon to good use. It looks really great! Simply stunning!
Once again, I'm lost for words when it comes to your precision!
Brilliant!
What Paul said!![]()
Thank you, friends. It's so nice to hear such high praise from you.Beautiful work.
Bill
