Those 0.6 mm bits are actually designed with PCB drilling in mind, not wood. They’re extremely hard but brittle as glass, with virtually no tolerance for lateral load, so even the slightest side pressure will snap them instantly. They’re great for straight-down work in fiberglass boards, but wood grain and hand pressure are a whole different story.While drilling and filing holes representing deck nails, the rate of drill bit destruction is worth noting. Using 0.6mm drill bits, if you apply the slightest bit of lateral torsion the little things just snape off. I bought 2ea. 10 packs of bits from Amazon anticipating this problem and already down 6 bits in one pack. Ha! you wouldn't want me drilling on your teeth!.
You might have better luck using regular twisted micro drill bits instead — they’re a bit more forgiving and much better suited for wood.
