Le Requin-Zebec-1750 POF 1:48 (ZHL)
While drilling and filing holes representing deck nails, the rate of drill bit destruction is worth noting. Using 0.6mm drill bits, if you apply the slightest bit of lateral torsion the little things just snape off. I bought 2ea. 10 packs of bits from Amazon anticipating this problem and already down 6 bits in one pack. Ha! you wouldn't want me drilling on your teeth! ROTF .
Those 0.6 mm bits are actually designed with PCB drilling in mind, not wood. They’re extremely hard but brittle as glass, with virtually no tolerance for lateral load, so even the slightest side pressure will snap them instantly. They’re great for straight-down work in fiberglass boards, but wood grain and hand pressure are a whole different story.
You might have better luck using regular twisted micro drill bits instead — they’re a bit more forgiving and much better suited for wood.
Thanks for the heads up, Jim. I had no idea.
The ones below are definitely not cheap; they are premium priced, but...take my word, they will last you much longer. They occasionally break when drilling metal or brass, and putting extreme pressure. But for the wood, I have not had a chance to break one yet.
I got the little Arrowmax pen style drill set from Amazon and it is great.
Interesting item Jeff.
I had the same problem drilling and found that normal drills are much better
I appreciate the input Daavey, I need to see how far I can get with what I have.
These above are the cheapest ones and they are the best for a job like this.
Thanks for the input, Stephan. I'll run through the batch I have then see what's available in the size I need.
