Please consider making a Donation to SOS to support our continuing growth and developement. It is greatly appreciated !!! *** Read More - - Click Here *** https://www.paypal.me/DonateSOS |
Witaj. Biorę przykład od Ciebie Mirku, cały okręt będzie w jednym odcieniu szelaku lub szelaku orange.Witaj
Piękne dekory ,powodzenia. Pozdrawiam Mirek
It's difficult to determine reality of a unit based on a few writings or boards. Each report is different, it's important to take goal and try to obtain the best information possible. There's a wealth of information about La Belle, but much of it is incorrect despite vast archaeological evidence.Waldemar, Thanks for the drawings of the Atlantic Merchant Barks that you posted above. I could believe that Le Griffon might have been similar to one of these vessels.
I enjoy reading archeology reports but sometimes it seems like what they really understand are Mast Steps. All else is inferred.
Roger
Figure is 38mm tall in 1/36 scale. It will be sized once i add a bowsprit. I'm trying to dissolve shellac to the correct color, both on wood and decorative elements.Nice prints. Are you going to show shellac ones too? Could you tell how long it took to print them and the height of figurehead
Waldemar, I won’t pretend that I fully understand all that you describe in your numerous reconstructions, but I am always learning, and I would like to express how much I appreciate what you bring to this forum.
Kuba, I am very interested to see what you do with La Belle - a vessel that I also consider a strong candidate for transitioning my skills from plastic to wood. I know what it’s like to have your enthusiasm for a project wax and wane, but I sincerely hope you will continue.
Thank you. This project is being created because i believe it's worth doing something on my own. Even if it's a POB, with a little effort and more time, you can create a model significantly better than the kit at a lower cost.Waldemar, I won’t pretend that I fully understand all that you describe in your numerous reconstructions, but I am always learning, and I would like to express how much I appreciate what you bring to this forum.
In my opinion, this is the pinnacle of the miniaturist ship carver’s art. The lines of this little ship are also very pleasing.
Agree. Ship is small, and it seems like a simple plan. In reality, however, it will require considerable commitment to build.Thank you, Waldemar. And, yes, I absolutely will transition to wood. I have always been inspired by this particularly brilliant execution of La Belle by Olivier Gatine:
1. Maritime archaeology is concerned with a very wide range of research questions, of which the history of ship design is just one. It may be your passion and area of highly comprehensive and detailed knowledge, so I can understand your frustration with reports that do not contain the specific information you want or seem uninformed, but maritime archaeologists have to cover a wide range of knowledge and few have the time or background to dive as deeply into the arcana of whole moulding. The ship is part of a larger context, including the cargo, armament, the crew and their possessions, etc. In the grand scheme of archaeological research and the limited resources that support it, there may be other questions that need more attention.
2. Archaeological hull remains show the hull as actually built, repaired, modified and worn out. This means that the theoretical design, however mathematically perfect it may have been, is only imperfectly represented in the remains. I can tell you from the process of building wooden ships (as a professional shipwright) that no matter how carefully the frame timbers are laid out, some amount of fairing of the frame surfaces is necessary to allow the planking to fit; this process can sometimes remove a surprising amount of timber, especially towards the ends of the hull, and especially if the hull was allowed to stand in frame for a year to season before being faired and planked. This is before timbers distort as the ship ages, are replaced in repairs, and lose original surface due to abrasion in use and erosions under water. So what we find in the ground needs some sensitivity to its post-design history to recover the original design thinking. Vasa is a good case in point, as its timbers were rough-shaped according to an original design, then adjusted and repositioned during assembly to widen the hull over 10% beyond its design breadth, which led to odd shapes in places (there is a long thread and discussion of this elsewhere on the forum). So the interpretation of archaeological remains requires more than a deep knowledge of design geometries, it also requires equally deep knowledge of the physical processes that affect ship timbers during construction, the working life, and the post-sinking decay of a vessel.
Most of us, and certainly the people I trained, are happy to share our data.
The other author went astray with a faulty interpretation of the dendrochronological evidence, which led her to believe that the ship was built from reused timbers from older ships going back over a century to the late 1500s. She had to construct an entirely fabricated historical narrative and identity for the ship in order to make this work, which invalidated virtually all of her conclusions.
Waldemar may disagree with his conclusions [i.e. Pevny's], but it should be noted that he places the design process in the same context as Waldemar proposes; he is not a complete idiot.
[...] he is not a complete idiot.
In return, I would like to be treated with equal respect.
Hi Allan.Fred and Waldemar,
This is one of the most intelligent conversations I have seen in a while. Thanks for sharing your thoughts and the respectful way in which you presented them.
Thank you, Thomas.Kuba, what a shame about the saw; perhaps you can repair it. Otherwise, there are always fret saws.
I wish you lots of fun building "La Belle." The model is worth seeing in any version! Use your obvious talent!
Best regards, Thomas
. Enjoy the day.
