Thanks, Brad. As I mentioned in another post I can envision how to cut the male end of the dovetail on a mill - but not the female end... so I end up just trying to do both by hand. The trouble happens when too much wood is removed leaving an open joint. If I can be more patient perhaps I can tighten things up a bit more.The outcome of this deck is incredible, even under the scrutiny of the close-up camera lens!!
Your dedication to putting in all the dove-tail joints is inspiring.
It's amazing how easy it is to create a tight full-scale dovetail, with sharp tools. At this scale you are getting about as close to perfect as possible! I hope you continue to improve on the next deck, as you are approaching what is possible at this scale.
Thanks for sharing this wonderful build, with such great pictures!!
Yes. A LOT of work for a deck that (even with an open-ended model) will be a bit hard to see. But I am satisfied that I put in the effort.Witaj
Pracy bardzo dużo ale jaki efekt . Warto było Pawle . Pozdrawiam Mirek
Hello,
It was a lot of work, but what a result. It was worth it, Paweł. Best regards, Mirek.
Cheers, Tobias. Thank you for your kind review. Alas, a clear understanding of the plans still eludes me.Good morning Paul, after all the questions and confusion surrounding the plans, your execution is a pure delight. Absolutely beautiful work, my friend.
Hi Charlie,Hello,
Great project and very nicely executed. Please allow me to ask a question. Where did you get your wood?
Hi Charlie,
Thank you for encouraging me. I sourced the pearwood domestically here in the US: https://www.rarewoodsusa.com/ (it is European pearwood, however).
The webpage for an excellent German vendor has disappeared. @Tobias can you assist our friend?
Another option might be: https://www.hobbymill.eu/products?fs=e&s=cl. This guy is in Estonia though I believe he only sells prepared boards and strips rather than raw lumber.
Hi Paul, that's right, Frank has changed his address slightly. Here's the new link.Hi Charlie,
