- Jul 27, 2021
What an incredible build, love every picture. The dovetails are outstanding!
A very nice alignment of those tint parts, Paul. A lot of measuring and fitting.Hello Friends,
Having test fit the lower deck beams I was able to begin installing them along with the (now fitted) beam knees. During this installation I was able to re-install the rider frames.
You will see a space between the vertical portion of the beam knees and the hull. The knees would ordinarily be fitted to the planking on the inside of the frames, but that planking is absent on my model (thus the space). Nevertheless, I still added mounting bolts to the knees which is sort of nonsense given the space but...
Next, I added the carlings (oddly, these longitudinal elements are placed at the vertical center of the beams rather than flush with the top of the beams) along with the dovetailed coamings and centerline spacers. These latter elements are only roughly fitted at this point - the joinery will need to be improved before final installation - but that can't happen until the ledges are fitted (also with dovetails). This will all make more sense when I show the installed ledges (probably in a week or two barring the unforeseen).
The French design makes deck fabrication tedious - my respect to people who are building full size ships and are choosing to include these details. The thought of doing this work for the remaining four decks is daunting - even on my stern section model.
I appreciate that you have taken the time away from your own work to visit.
Hi Paul, are you using your mill for most of these notches or are you using small chisels or both (I am assuming the later). Very precise work. Re the spaces between modelers will add extra dimension to the knee to compensate for the lack of planking. I know I will need to do that on the unplanked side on La Renommee for rigidity. Leaving the space works well to on your model !Hello Friends,
Hello Andreas,Wonderful, loving work with great insights into the construction.
Keep it up!
Thanks, Oliver! My first standing ovation in ship model buildingBravo! Standing ovation!
.Indeed. It would be easier if I could send the parts to you for sanding...Did you sand everything by hand, Paul. This is one tedious project.
Hi Brad,Those dovetail joints are incredible!!
I see the bolts going into the (imaginary planking). Gives new meaning to "hanging" knees! They look great and it was a good choice to include them!
Question: Did the plans show bolts on the knees (parallel to the keel) which connected them solidly to the beams?
I placed them on my Bonhomme Richard build (photo and sketch below).
View attachment 575002View attachment 575003
Your work is simply stunning. Somehow, I never get alerts to your post, even though I unwatch and rewatch every time I visit. I will continue to check your log, in the hopes of new post/photos!
Thanks, Grant. I'm trying to include as much eye candy as possible given the unique viewing opportunities possible on this section build. That said, in the middle of fabrication, I find myself thinking, "you sure you want to spend the next year of your life building decks, Paul?"Good morning Paul. Brilliant as always. Man you have thought of everything and willing to have the patience to include them. E.g. the spacing on the vertical knees where the inner planking would be. Respect. I don’t know how you achieve such perfect notches and dovetails but they make wonderful viewing.
Yep me too. It’s OK with Paul because I don’t forget to check his work out.
Cheers Grant
Thanks, Dirk. They look better when they are not magnified 10 timesWhat an incredible build, love every picture. The dovetails are outstanding!
. Of course, some are better than others. I chose some average ones just to show that I am including the detail.Truly. Lots of measuring and fitting (and frustration when all the measuring and fitting turns out just OK...). But its a hobby so I choose to press on when things don't turn out perfect.A very nice alignment of those tint parts, Paul. A lot of measuring and fitting.
Hi Chris,Hi Paul, are you using your mill for most of these notches or are you using small chisels or both (I am assuming the later). Very precise work.
I believe your planned solution is the accepted standard though I have also seen several models doing it the way I am. Once I committed to having the rider frames float I was more or less committed to this approach.Re the spaces between modelers will add extra dimension to the knee to compensate for the lack of planking. I know I will need to do that on the unplanked side on La Renommee for rigidity. Leaving the space works well to on your model !
You have it right, Herman. Drill a hole and then square it up with chisels. The slot on the other side is easier and faster (and more uniform as it was done on a mill). Of course things run off line sometimes but I hope the overall look will be acceptable.Great work on this lower deck. Fantastic precision job.
The carlings on one side are lowered into a slot. I assume you made a hole into the deckbeams by drilling and further using a small chisel for the fixed side of the carlings?
Thank you, Mirek. You are always very kind and encouraging!Witaj
z przyjemnością ogląda się twoją prace Pawle. Pozdrawiam Mirek
Hi Ken. Thanks very much!Just wonderfully clean, and precise work, Paul. A feast for the eyes!
I'll take this opportunity to respond to my own postingWhile my plans are (as far as I can find) silent on the question of bolts joining the knees to the beams they obviously would have been there.
.I think I have enough of my own to sand. I wouldn’t do as well as you anyway.Indeed. It would be easier if I could send the parts to you for sanding...
