Golden Hind 1/72 by Aifix with added rigging and details
Good day John,
One of the option, making this triangle decor, to use sharp fine blade making borders of this triangle, than slowly to fill in area of this fine cutted borders with liquid paint in several strokes...You need fine brush for this...and first try this technique on some other area not on the model.. I did it on my model and it works well...maybe slowly,but gives very fine and clear borders between different colors on the flat surface...
But You need to cutt this fine triangle cutt very accuratelly and very fine almost non visiable, but only for cappilar effect which gives You sharp and fine border between two different colors...
:))) why You did clouds green on the stern shield?
And You should give Elizabeth I reign coat of arms symbols in priority of FD coat of arms on the stern shield , this black and white shield...I think it was given by El I to FD, knighted, after this famous voyage... than shouldn' t be here yet, but I could mistake ... if You have time and interest in historic background, You could" vent" this question, what simbols could be seen on the GH stern shield?
Ah...I did not see them as clouds! I thought they were trees...on either side of the view! They would have to be cumulus clouds given the shape and I didn;t think they looked right. I also looked at others and most (?) had painted them green, which is also probably why I thought they were trees. I mostly used the work of swlusk here as the basis for my version. And reproduced below. I am going to try to add some cirrus clouds and some texture/shading as he has done so nicely!
You are of course correct! FD was knighted, and presumably given his Coat of Arms, after he returned. So it should not be on the ship untyil AFTER he returned. But...maybe I ammodelling it after it was put on display follwoing the voyage :-) More info on this is here, by rkwz, who also noted this inconsistency.
Good day John,
That is an interesting idea. I am not sure my skills are capable of it, but I might experiment with the technique.
Someone (Harry Houdini, in Australia) suggested painting the light colour along the hull, and then painting the dark colour on paper which is then cut to the correct size/shape and glued into place. I guess this also works... Not sure which approach to use yet!
I have added some clouds and tried to put some texture in the grass, leaves and the hind itself.
Good day John,
Hi Kirill
here is a closeup picture of the hull. The triangles are actually marked in the plastic...slightly raised lines. So they *might* be useful to give straight lines. I expect that your technique would not work because I would first need to remove these raised lines, so I can replace them with your cut lines? Have I understood?
There are a couple of sections that I plan to cover in red and yellow triangles. So obviously I will paint those sections yellow and then add the red over the top. So that gave me the chance to try yellow triangles and see how I manage. I was pleasantly surprised by how well it worked! I used Posca paint pens (suggested by Harry Houdini) and they worked well.
That was simply drawn freehand. The slightly raised plastic lines are indeed a help, and provide a little guide to the hand and eye, and a small resistance to flowing paint. So I am hopeful that I will be able to do this neatly and by hand...which will also be quicker than most other methods. I finished doing one section and it looked OK to me.
So while continuing to experiment with triangles (damn triangles!) I was reminded that I need to add the anchor cables before closing the hull. I noticed that there are no holes in the hull, and indeed there are no holes in the piece that is to be attached to the hull. So that is done, while I contine to sweat over these triangles...
I have done some experiments with painted paper triangles. There is some wood grain in the plastic so thin paper would be required. I was told that cigarette papers were a good choice, so I tracked some down.
Now, I was originally intending to use the Posca Pens so I have picked the colours I want and painted much of the hull with them. The yellow is actually called "apricot" and the red is "dark red". I have done the line of blue and white and it is OK....more tidying to be done. But I thought I would try the red (and background yellow) triangles with paper and if that works I can go and re-do the blue and white. I am locked into using the posca pens because I have started with those colours. But the posca pens (although very useful for some things) are not so good on absorbent paper. The paper crinkles and the strokes of the pen are hard to hide. Grrrr. I have been told that airburshing might work so I will try that.
As a displacement activity I have begun construction of the guns for the gun deck I will be adding. It was suggested that the guns be wired onto the carriages in case the glue fails at a later date. It will of course be impossible to get into the deck once the hull is assembled. So I figured I would also wire the gun carriage to the deck (as well as the gun to the carriage). Here is a prototype. Two holes were drilled through the bottom of the carriage, with relatively thick wire through them, which can then go through the deck below. They will hold the carriage in place and also hold the orientation. I ran a thinner wire througn the holes in each side of the carriage. These are normally for eyebolts and tackle, but I am not including in the guns on the gun deck because they will be barely visible. I am hopeful that this will all work. And hopeful that I can get a deck in the right position!
I have just completed a deep dive into halyards and knights (thanks to Kirill for steering me to the right references). This is only my second ship, and the first (Endeavour kit) had no halyards and the extra rigging I included was a reduced set - with no halyards. I noticed that the knights in the Golden Hind kit had no sheaves - probably because there are no halyards in the kit.
But I am adding halyards - so I spent a couple of days learning about them (and understanding the difference between halyard tackle and jeers etc). I will have to add three sheaves on two of the knights, and two on the mizzen knight. I have lovely ramshead blocks from HiSmodel to make the tackle. Anyway, after a few hours of careful (and slightly terrifying) work I got something that I am happy with. When painted I think it will look good.
I come seeking advice ... on pumps.
The Airfix Golden Hind does not include bilge pumps. I think they were probably present. So I have bought one that I think is of the right kind.
The scale seems right - the figure is from the kit.
My questions are
1) is this the right sort of bilge pump for the time?
2) I assume there should be a pair?
3) And they should be either side of the main mast...
Thanks for any advice!
JohnL
I think I have answered my own question :-)
I looked in Lavery's Anatomy of the Ship book on the Susan Constant, 1605, a contemporary of the Golden Hind. The two ships seem very similar. Anyway, the pump looks right, and there are two, and they are near the main mast.
And here is the description from the book.
("The Moon" is a contemporary of the Susan Constant (and hence GH) for which there is more information; Lavery used it as one of his references for conclusions about the Susan Constant.)
Diagram A4 shows the pumps are not on the weather deck, but the gun deck.
If the GH followed the same design then this might be why Airfix did not provide pumps for the kit...
Maybe I should NOT add pumps to the GH weather deck?
Anyone got any knowledge of this?
John L
And now for a question about the longboat. But this time I have read the Susan Constant reference first :-)
It is thought that the Susan Constant had a shallop as well as a longboat. Especially because of its lengthy voyage, and I expect that would also apply to the GH. It is likely that a longboat would be towed along behind, but I don't want to do that so I will add it to the weather deck. I bought two boats that I think are suitable. Here are the dimensions from Lavery's Susan Constant book, based on another contemporary ship of similar size:
So the length is 21'3" = 255" = 647.7cm which, on 1/72 scale, is about 9cm. The boats I have are about 7cm, which is close enough for me.
The width is 7'5" = 89" = 226 cm which scales to about 3cm. Mine are about 2.5 which again is clsoe enough for me.
The example given in the Lavery book is below, which is more like the shape of the boat on the left.Pic-1165.jpg
But I like the one on the right more so I think I will use that one :-)
JL
Next time I make knights...I will put the sheaves a bit lower so the eyelet can go above them. I think that seems to be more realistic? At least it is a better match to what I see elsewhere...
And not being very bright, I just realised that I will have to add sheaves to the masts as well. The kit does not have them as it does not include halliards.
Yet another thing to do...
Beakhead almost done :-)
The original airfix beakhead has no holes, just indentations... (well, 2 holes for the gammoning) and the wooden veneer deck from HiS model has the correct holes, of course.
I have just spent the better part of two days (!) carefully removing the indentations. I could have just cut out the entire interior and fixed the wooden deck to the edge. But I wanted to keep the plastic ribs under the wooden veneer, so it looks like they are 3D pieces of wood rather than just a surface. So lots of pin vise, careful knife work, filing of various sizes, and the job is done. I had to be wary of applying too much pressure when cutting and sanding, because I did not want to break any parts. But it seems to have come out OK.
It lines up well...
...and when viewed at an angle it seems that the wood has depth as well!
Painting next!
Seems I am an idiot. (This theory fits all the data I have collected so far...)
When I look at the masts, they already have the holes in them for the halyards!
Now, precisely why they would have these holes when the kit does not have any halyards, is a question for Mr Airfix I guess.
EDIT: In the following post I say "yard tackle" and I should have said "mast tackle". No wonder I got it wrong in places! Andersen says "no yard tackle" but I should have been looking at mast tackle. Sigh.... Corrections below in [square brackets] to avoid further confusing anyone who read this :)
I am now trying to sort the belaying points, since I need to get the deck sorted soon.
Way back in post 66 (and following) I was confused about the rigging diagram, and the names of the lines belayed to the channels of the fore and main mast. Kirill explained that the one on the right (nearest the front, green in the diagram below) is a yard tackle [he said mast, but I incorrectly remembered as yard!]. I think the one to the left (rearward or "abaft" if I have the language correct!) is a "running back stay" (red in the diagram below) as we discussed in post 77 and thereabouts.
And I am happy with that - as long as I have the names right :)
And then I read in Anderson's great book: "..I rather doubt that I should venture to fit (yard tackles) at all before 1685." (p 156) [True - but mast tackles were used!]
So I am again torn...I think the yard tackles look good but maybe it is more accurate to not include them?
I note that the book "Anatomy of the Susan Constant" (a contemporary of the Golden Hind from 1605) does not show any tackles.
But Hirsch, in his book on galleons, shows two lines going through a tackle from the channel to the top, for each of the fore and main masts. He labels them as backstays; see post 75. I think the forward one is just mis-labelled. It should be a yard [mast!] tackle (as Kirill pointed out in post 78 - I am starting to catch up with where Kirill was a few months back!) . Mondfeld also shows both a tackle and a backstay, see post 92.
So I am happy with identifying these lines as yard [mast] tackle and backstay. the question is whether the Golden HInd had yard tackles!
EDIT: No yard tackles but deinifitely (!) had mast tackle and backstay
Sigh... I know...we will never know!
But thinking out loud is helpful for me
Any wisdom gratefully received, of course!
JL
P.S. And just to perfect the confusion...Eugen's diagram shows TACKLES but no STAYS for the fore and main mast....
