Royal Louis - Mamoli
I’m now moving on to second planking the lower hull using 4x1mm walnut strip. I once tried using the supposed correct method of planking but without a great deal of success so I’m not going to start like that again on such a difficult hull. I’ll just concentrate on getting the planks down flat and neat with only one eye on a sort of correct flow so if pointy bits offend your eye look away now. I use both white glue and cyno for attaching the planks. I have already sanded the edges of the planks to get a nice clean fit, also to help a clean looking fit after I’ve laid each plank and whilst the glue is still moist I lightly sand the area, this removes any surface glue and at the same time fills any gaps with sawdust, especially helpful where I’ve put in fillets. I found that the way that I introduced the rabbet line has worked very well.
Have you tried stealers in the past? They didn’t seem to be so hard to make.
Agreed. Plan the stealers out, identifying pinch points or expansion point areas, and make them in pairs, port and starboard. Draw pencil lines on the loose planks you about to tape and attach, and test fit. Once you get used to the thinking involved in predicting where to install stealers and drop planks, it does get easier. No pointy planks required.
Lovely Ken. Very neat planking. Cheers Grant
  • Like
Reactions: Ken
Hi Kurt. I totally understand what you’re saying and seeing your work I can see why you would like to see all hulls done that way. This will most likely be my last build, I know what I can achieve doing it a simple way, this will be a difficult enough hull to do as it is so now is not the time for me to push the boat out. I’m afraid that you’ll have to turn a blind eye to it. Ken
I understand. We have to work within our limits. Thanks Ken!
  • Like
Reactions: Ken
Good morning, as you can see it's a nice sunny day, hopefully were coming out of winter and into some better weather. This is just a short pictorial update showing my humble effort at planking. I'm happy so far, the seams are tight and there are no sprung planks.
Hi Ken,
very nice progress.
Unfortunately, now that the weather has turned and we have some sunny weather, I have received new orders from my commander - garden! Hopefully, I can keep my build going, and do all the other "stuff". If it stays nice we will try to have a ride up your way and drop in to say hello.
Dom
