You’re doing fine. This kit is on my short list for my next project.
I think it looks great. I found this build frustrating put mine aside for a while.
Neil
Looking at it from the bright side: this is a hobby in which I expect and hope to have difficulties. This kit guarantees that requirement.
I did not give up, just frustrated put it aside for a while and built another kit.One more modeler that gave up this kit?
Several other logs end up more or less the same way.
Hope you may pick it up again soon, Neil.
Hi Tony!I think many instructions were translated from another language to English. A lot gets lost in translation. I though Maristella had good instructions ?? Not the case ?
Yes I have walked away from this kit several times over the last 2 or 3 years. Mine is the older version model. the transom is a bitch and trying to deal with it But I do come back to it while working another model. Anyway I have totally gotten rid of the kits instruction and I am now just common sensing it together my own way and now seeing a little progress....Four and a half years later I now realize that some of these instructions Suck no matter what you spend on the kits , so hang in there Neil and think it out with you own mind ,and little by little you will get their.....Thanks for posting ,At lease I know I am not alone.......I think it looks great. I found this build frustrating put mine aside for a while.
Neil
Thanks I'm still plugging away at mine.Yes I have walked away from this kit several times over the last 2 or 3 years. Mine is the older version model. the transom is a bitch and trying to deal with it But I do come back to it while working another model. Anyway I have totally gotten rid of the kits instruction and I am now just common sensing it together my own way and now seeing a little progress....Four and a half years later I now realize that some of these instructions Suck no matter what you spend on the kits , so hang in there Neil and think it out with you own mind ,and little by little you will get their.....Thanks for posting ,At lease I know I am not alone.......
We don’t know why kit makers make certain parts and instruct us in the way they do. All in all kit builders should have the means of making parts if needed. The instructions are extensive I see and a thorough read or several reads might help along with making notes if things aren’t explained clearly.Hi Tony!
In my opinion it is not only an issue of translation.
Construction steps are sometimes addressed more than once in different parts of the instruction booklet (298 pages...) and not always in the same way.
Different methods are proposed, with different materials.
For instance, the sheaves for the six sheave blocks to be embedded in the hull wall can be made from photo-etched parts, or laser cut wood parts.
In one part of the instruction book, they instruct making the 2 stern block sheaves by gluing two 0.5 mm-thick photo-etched halves and the other four middle-ship blocks sheaves using laser-cut parts. Don’t have a clue about the reason for this difference. The blocks are exactly the same (dimensions, function, installation in the build…).
In one other point of the instructions they write that the sheaves may all (the 6) be made with laser-cut parts.
Finally, the kit provides six laser-cut discs labeled with the 6 block references, but does not provide sufficient photo-etched parts.
For a modeler like me, perhaps below the level required for this kit, this is confusing:
1st question - why have two different construction methods for the stern blocks sheaves, if they are basically equal to the other four middle-ship sheaves?
2nd question - why don't the parts supplied match the first construction method?
3rd question - why have more than one option for the same thing (photo-etched or laser-cut)?
The issue can be easily solved by forgetting the photo-etched parts and using only the laser-cut. Alternatively new sheaves may be made out of a wood dowel.
But it is annoying and not reassuring for the rest of the build: I find these issues as I go along and never know if there will be others ahead, more difficult to solve.
The ship model is very interesting, but, as I wrote before, the kit would benefit from a review of the instructions.
Best regards
Catela
