G'day John
You can use this part of the spindle and it should be quite easy
Just chop of the top of it and it should fit ok.
Hello John,View attachment 70336
Well that's both the main head rails cut out and had the mouldings cut in to them, nothing too fancy,
another view
Before I can attach the head rails I need to install the beak head bulkhead, this shows it glued and dowelled in position,
another view from head on,
I photo copied and cut out the part of the plan for the bulkhead and then held it in place just to check all will be OK,
the planking of the forecastle deck had to come flush with the top of the lowest moulding which is the moulding
just above the gun ports,
So this is the beam installed 2mm below where the moulding will come to,
For the little spindles that go across the bulkhead, I have approx 200 of these little walnut spindles, with a bit of
work I think they will be OK,
once again thank you for all your comments and likes,
best regards John.
Hello John,
Everything looks fabulous thus far. In regards to the 200 spindles, did you make them yourself or was it one of your wonderful acquisitional skills? If so, where did you get them?
Ray
John,
Truly remarkable. The joints are tightly fitted and there are no visible gaps. Will the knight heads be carved in or do you already have a surprise waiting for us?
Ray
Hi John,
I'm overwhelmed looking at the speed and exquisite craftsmanship that you are sharing with us. Bravo.
,Never underestimate the power within you, because you may be the only person in the entire universe to solve a specific problemI think a lot of it is pure fluke,,
Hey John,
The stanchions are looking great (all your ducks in a row). Looking forward to more of your progress.
Ray
Great work again John. Already some ornaments in mind for this bulkhead?
